  #81 (permalink)
Old June 24, 2009, 06:42 PM
Dazmode's Avatar
Originally Posted by Z Overlord View Post
say, could I get some good tubing at Home Depot? Other sites are giving Shipping and Handling that cost more than the tubing itself
That's hard to believe... are you live at North Pole or buying 1ft only?
Orange Build: Final Video
HTPC Build: Final Video
  #82 (permalink)
Old June 24, 2009, 06:43 PM
Akai's Avatar
You could... however its going to be standard PVC tubing and to be honest it doesn't usually bend as easy or look any where near as nice. Plus cheap tubing has a tendency to become cloudy after time.
If I was you I would just try and order everything from one spot, I managed to get a good bulk of my parts from performance-pcs and NCIX, and by browsing the Buy & Sell here.
You should be able to get that res, tubing and barbs all from NCIX. Just do one big order to save on shipping or do the gift card trick! And just price match if you can get it cheaper else where. (Purchase a $10 gift card at NCIX and get free ground shipping on your entire order then you still get to use the gift card later Almost as good as free shipping LINK)
EDIT: Nevermind it seems the Free Gift card thing isn't working right now... but ive done it before, it comes and goes
  #83 (permalink)
Old June 24, 2009, 09:06 PM
So I got everything ordered, everything's fine.
So, about the loop (single loop, correct?). I want to visualize, I get how it works, and any setup problems I could figure out or ask on the internet.
So how's the order go?
res-->Rad-->cpu-->gpu
where does the pump fit in? I could figure it out when the stuff comes but I might as well have a better mental image of how it works.
  #84 (permalink)
Old June 24, 2009, 09:50 PM
KaptCrunch's Avatar
REZ>PUMP>rad>cpu>gpu
  #85 (permalink)
Old June 26, 2009, 09:39 PM
so with the rad, I put the fittings in it, connect the tubes and just have it flow? the ends don't matter? I wondered this, how does it cool the water lol? the rims absorb heat right?
  #86 (permalink)
Old June 27, 2009, 07:05 AM
ChuckleBrother's Avatar
Direction of flow doesn't matter, there are channels that basically loop around from one fitting to the other, this water sheds it's heat from the channels into the fins and the air blown by the fans removes it from the fins.
Plumb it up whichever way is neater/easier.
"...you play a mean banjo"
  #87 (permalink)
Old June 27, 2009, 10:51 PM
how much Distilled Water would I need? I will just use some funnel to fill it I guess...
And how do I drain it? (I'm supposed to do this yearly right? Or when I replace Hardware).
  #88 (permalink)
Old June 27, 2009, 11:38 PM
aviduser's Avatar
Buy a 2L jug of distilled and you'll have plenty. I'd be suprised if you used half. You can drain it via the reservior, or simply pull a component out of the case and pull the hose off (over top of a bucket of course).
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
  #89 (permalink)
Old June 28, 2009, 09:13 AM
2L will be fine to fill, maybe get a bit extra for leak testing(first time is a bitch).
  #90 (permalink)
Old June 28, 2009, 10:54 AM
Supergrover's Avatar
I tear down my loop every 6 months, by then your rad will probably need a good cleaning. Depending on the fluid your components might need a thorough cleaning.
R.I.P.
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
