  #71 (permalink)
Old June 19, 2009, 09:47 PM
hmm, so you can't make an account at sidewinders? It seems like there is no option.
  #72 (permalink)
Old June 19, 2009, 09:55 PM
MpG's Avatar
MpG MpG is offline
iirc, you don't have an account there, you just fill in your shipping/personal info during checkout.
  #73 (permalink)
Old June 20, 2009, 12:09 AM
what should I use to put the water in the res? Some type of funnel?
  #74 (permalink)
Old June 20, 2009, 12:50 AM
MpG's Avatar
MpG MpG is offline
Whatever gets the water into the reservoir, without it spilling anywhere else. A funnel should work fine.
  #75 (permalink)
Old June 20, 2009, 05:51 PM
So will I need 3/4 hose clamps for this tubing?
NCIXUS.com - Buy Primochill Primoflex Pro LRT UV Blue 1/2IN ID 3/4IN OD Tubing (10 Feet) - PFLEXP10-34-B.
I mean, do all my parts fit together? No need to change sizing/barbs?
  #76 (permalink)
Old June 21, 2009, 09:37 AM
bump(s)
  #77 (permalink)
Old June 21, 2009, 03:14 PM
MpG's Avatar
MpG MpG is offline
Yes, those are the kind of clamps you would need, and the list was looking good last I checked. The document you have attached doesn't work, though.
  #78 (permalink)
Old June 22, 2009, 02:14 AM
Hose/Tubing:NCIXUS.com - Buy Primochill Primoflex Pro LRT UV Blue 1/2IN ID 3/4IN OD Tubing (10 Feet) - PFLEXP10-34-B.
inch steel hose clamps from the hardware store
Distilled Water
So do I need to buy my own biocide? And why would I need 1/2" hose clamps if the outer size of the tubing id 3/4 or something?
  #79 (permalink)
Old June 22, 2009, 07:29 AM
MpG's Avatar
MpG MpG is offline
Actually, that particular tubing is anti-microbial, which means that it will handle biocidal duties by itself. So nothing extra needed there.
The tubing has two measurements - its inside diameter (ID), and its outside diameter (OD). In this case, it's 1/2" ID and 3/4" OD. Your fittings are 1/2" so that they can go inside the 1/2" ID, and the clamps will need to fit around the 3/4"OD. Once you get the tubing, I'd suggest just taking a 1-inch piece to the your hardware store and picking up the smallest clamps that still go over it easily.
  #80 (permalink)
Old June 24, 2009, 06:28 PM
say, could I get some good tubing at Home Depot? Other sites are giving Shipping and Handling that cost more than the tubing itself
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
