Originally Posted by Dazmode SugarJ -- nice rig. |
Thanks Daz. That's the old build, my Cosmos is much nicer. I should put some pics in the pic thread.
Originally Posted by Z Overlord but what about the other Q's I had like the Rad Box? Do you still need it if I'm mounting inside? It's my list I'm worried about. I want to remove unnecessary stuff from it, budget is somewhat tight. |
Radbox is not necessary for internal mounts, but you'll have to come up with some brackets like I linked earlier.
And those barbs are correct for 1/2" tubing, but Bitspower barbs are WAY better, IMHO.
Bitspower G 1/4in. Silver Shining Fitting for 1/2in. Tubing #BP-WTP-C01
As for the spotcool, it's not necessary if you have decent airflow over your mobo with your rad mount. With my 900, I was pushing air through the rad, over the mobo, and exhausting with the top fan. I never found I needed my spotcool, but your mileage may vary.
