  #51 (permalink)
Old June 16, 2009, 07:54 PM
aviduser's Avatar
I've always used a razor blade to cut the tubing. You'll need a biocide whether its silver or pt nuke if your running distilled.
Thanks for bringing that to my attention about the barbs. Can't find if its a case of metal barbs being easier to overtighten or if its somehow related to tolerances. I guess I'll keep my fingers crossed.
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
  #52 (permalink)
Old June 16, 2009, 09:58 PM
And this will all be one loop? TBH, I'm having trouble finding the right kind of barbs, it seems like I can't differentiate one barb from another.
  #53 (permalink)
Old June 17, 2009, 12:20 AM
MpG's Avatar
MpG MpG is offline
Originally Posted by Z Overlord View Post
Well I know NOT to use medal barbs for that particular res. because it says they crack it (other ppl have confirmed) Will I need biocide then? How so minus barbs for res.
And what do I use to cut the tubing?
I'm also noticing how a bunch of my stuff is Swiftech, why don't they just release a bundle pack like the Orange Box?
Also the barbs need to be 1/2,
Swiftech High Flow Fittings 1/4in BSPP thread to 1/2in ID Barb
why does it say 1/2 and 1/4?
Actually, there are a number of Swiftech kits that can be had at places like NCIX.
I've always used metal barbs in my own MicroRes without any troubles. In fact, I'm using them right now. It's possible to overtighten them, but you honestly have to torque the fitting pretty hard before that happens.
The 1/2 and 1/4 refer to the two ends of the fitting. The threaded part is BSPP 1/4 sized (for our purposes, that's the same as the G1/4 size that you'll see on most parts), while the 1/2 refers to the other end being sized for 1/2" tubing.
  #54 (permalink)
Old June 17, 2009, 07:21 AM
Dazmode's Avatar
Or you can use EK Multi-res with Acetal top and bottom.
Orange Build: Final Video
HTPC Build: Final Video
  #55 (permalink)
Old June 18, 2009, 05:23 PM
Are t over custom? I mean, $400+ US Dollars is pretty expensive for the custom stuff. The kits are like $300USD
  #56 (permalink)
Old June 18, 2009, 05:28 PM
Dazmode's Avatar
Kits are cheapest crap together. I'm talking about something half decent.
Check this (i have some pricing here):
DazMode • View topic - Watercooling build HAF932 i7 Step-by-step in pictures
  #57 (permalink)
Old June 18, 2009, 05:56 PM
Oh and if I'm mounting the Rad inside, do I still need the radbox?
Newegg.com - Swiftech MCB-120 "Radbox" - Case Fans
Someone recommended me it when the plan was to mount the rad outside.
And regarding this:
Newegg.com - Antec 0761345-75018-9 Blue LED Case Fan - Case Fans
Do I really need it? It's a hotspot for cooling my chipset.
Oh and how do I mount the rad inside? I screw it with what? I want the inside of the front of my Antec 1200 (removing HDD cages). And can I moun it to the ceiling of the case even though it has a HUGE fan there?
And are these the right fittings? (1/2in)?
  #58 (permalink)
Old June 19, 2009, 12:32 PM
bump for last minue
  #59 (permalink)
Old June 19, 2009, 12:45 PM
SugarJ's Avatar
Z, take a look at this thread. http://www.hardwarecanucks.com/forum...c-project.html Page 5 shows how I made the brackets to mount the rad in the drive cage. Should be the same idea for you in the 1200.
  #60 (permalink)
Old June 19, 2009, 12:50 PM
Dazmode's Avatar
SugarJ -- nice rig.
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
