  #31 (permalink)
Old June 10, 2009, 11:04 PM
MpG's Avatar
MpG MpG is offline
The list is looking good, I'd say. If you don't have any, maybe grab a pair of el cheapo pliers to tighten the fittings with. Finger-tight is just fine 99% of the time, but it's always good to give each fitting an extra 1/4 twist to make sure it doesn't work loose while you're pushing the tubing on.
  #32 (permalink)
Old June 11, 2009, 03:04 PM
when testing the loop, can I test it not in a case? Like just laying on the floor? Oh and you know my tubing? Is there a clear version of that exact tubing? Thanks.
  #33 (permalink)
Old June 12, 2009, 05:46 PM
bumpa
  #34 (permalink)
Old June 12, 2009, 06:23 PM
SugarJ's Avatar
Yes, you can test it outside of the case. I wouldn't suggest laying it on carpet though. As for tubing, I don't recall what you linked, but I've used the Masterkleer and Primochill (in UV Red and Black), and I'd recommend the Primochill.
  #35 (permalink)
Old June 12, 2009, 06:44 PM
Dazmode's Avatar
I test inside the case, but I power pump with external power supply.
Orange Build: Final Video
HTPC Build: Final Video
  #36 (permalink)
Old June 12, 2009, 09:10 PM
but if there ARE leeks, won't that brake my hardware? Water can't be good for electronics
As for clear tubing, how's this?
NCIX.com - Buy Primochill Primoflex Pro LRT Clear 1/2IN ID 3/4IN OD Tubing (10 Feet) - PFLEXP10-34 In Canada.
And what rad?
NCIX.com - Canada's Premier Computer Store - Great Technology, Service and Selection.
Oh and on my list, how much of each do I need? (Like barbs, clamps, etc.)
  #37 (permalink)
Old June 12, 2009, 10:20 PM
Sadasius's Avatar
Your right water is not good for electronics. But if the electronics is not on the there is no harm. Just clean it up and let it dry out for a few days if you leak all over anything and try again. Leak testing outside the case is kind of useless because everything will loosen up on you when you go to put it in the case after testing and thus causing a leak. So what you use is a cheap power supply, cut the green and black wire that are next to each other on the part that plugs into a motherboard. Twist them together after stripping the ends and tape them together using electrical tape. Please do not plug it into a motherboard...ever. This will be your leak testing PSU from now on. I use a craptacular 300watt PSU from some old IBM system. When you plug this into a wall it will automatically be on. So plug in your pumps and fans on your rad and then plug it into a wall. Make sure as well that there is always fluid going to the pump. Shut off and on the PSU as needed. I like mine because it has a switch on it to turn it off and on and is great for leak testing (if you have no switch just unplug at the wall). I fill it up a little, turn on the power for a sec and then turn it off again and fill some more. Keep going till it's all full. Here is some pics of the leak testing PSU.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Last edited by Sadasius; June 12, 2009 at 10:38 PM. Reason: Took some pics as examples!
  #38 (permalink)
Old June 12, 2009, 10:39 PM
Yeah everyone thinks water + electronics is bad. If there is any electricity this is very true. I hooked up my loop inside my case and powered it from another computer's PSU. You could do it externally too. It'd be a good way to test each part if you're concerned.
  #39 (permalink)
Old June 13, 2009, 01:47 PM
I see what you did there with the black and green wires, but what do you do with it?
Oh and what of this?
NCIX.com - Buy Logisys CLK12UV2 Dual UV Cold Cathode Kit 12IN 3.0MM - CLK12UV2 In Canada.
Some guy told me to get them.
  #40 (permalink)
Old June 13, 2009, 02:12 PM
Yep, I saved a buddies laptop when he poured a glass of water on it.. I turned it over fast and yanked the battery out, no damage at all once it dried!
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
