  #21 (permalink)
Old June 8, 2009, 12:02 AM
hmm, so wetting the hardware when it's off doesn't harm it?
Oh and when I'm testing it, can I just use plain tap water just for the test? Don't want to waste some of my liquid Coolant.
  #22 (permalink)
Old June 8, 2009, 12:07 PM
Dazmode's Avatar
Negative, unless you want all crap in the tap water to end up on your blocks. Use distilled water from grocery store.
Orange Build: Final Video
HTPC Build: Final Video
  #23 (permalink)
Old June 8, 2009, 12:38 PM
gingerbee's Avatar
Use distilled water from grocery store. this is a 100% yes
  #24 (permalink)
Old June 8, 2009, 02:11 PM
element291's Avatar
My 1200 is WC. I think you should mount the dual rad inside the front, (take out 2 lower HD bays) Its a lot cleaner looking and is basically hidden. I have 4 scythes mounted on mine, and the stock case fans also push air through the rad.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
  #25 (permalink)
Old June 8, 2009, 05:39 PM
Okay I'll use distilled...
Thanks for the tip for the Antec btw. Can a triple Rad fit into there? Probably not lol, I should just stick with dual rad.
BTW, besides the rad's, how many other fans do you use and where do you put them? I want the least as possible, I hate fans
  #26 (permalink)
Old June 8, 2009, 06:35 PM
Dazmode's Avatar
I think with triple you need to give up DVD drive...
  #27 (permalink)
Old June 8, 2009, 07:38 PM
ChuckleBrother's Avatar
I use a total of 7, 5 of those being located on my radiators. I have an intake at the back so that fresh air runs over my ram and into my top mounted rad and an exhaust in the front to expel heat from my harddrive and fan controller and pump.
Run em at ~1100RPM(S-flex) and they are basically silent.
"...you play a mean banjo"
  #28 (permalink)
Old June 9, 2009, 03:23 PM
K, so I'll go with Double Rad so I need 2 of those Noctua fans. How much of all that stuff in my list do I need? Is the list set and read for ordering? Anything else I'm missing before I order?
  #29 (permalink)
Old June 10, 2009, 09:16 PM
bump for suggestions
  #30 (permalink)
Old June 10, 2009, 09:20 PM
Dazmode's Avatar
Ha-ha, the only suggestion use my store LOL!
On serious note, looks OK. It's hard to get 100% sure anyway. Always some small stuff get forgotten for somebody's particular situation.
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
