  #141 (permalink)
Old July 4, 2009, 01:37 PM
So would Primochill be more flexible? Cause the Home Depot Tubing is very unflexible, had to get all these elbows and stuff (what you said I should get earlier, those aren't elbows, they're fittings). 1:34, just an hour and a half till my 24hr test is done. No leaks at all, very good, thanks guys :)
  #142 (permalink)
Old July 4, 2009, 02:45 PM
MpG's Avatar
MpG MpG is offline
Yeah, most of that hardware store tubing is pretty bad for bending, and a lot of it isn't even very circular. You should see a noticeable improvement with some proper watercooling tubing (i.e. Tygon, Feser, Primochill, etc)
  #143 (permalink)
Old July 4, 2009, 02:52 PM
and what about elbows? I just use these cheap thins (when the tubing bends too much, I'm not talking about what connects to the blocks and res and all that).
As for 90 degree fittings (not elbows), wouldn't the res's hinge thing block me from putting it in? And what of all the res's bubbles. They're all hanging around there, on the top. Do they ever leave or do I just leave them there forever?
  #144 (permalink)
Old July 4, 2009, 02:55 PM
Jackquelegs's Avatar
Don't worry, that's the job of the res to bleed out the bubbles.
What did you mean by the hinge of the res?
Word of advice, don't put too many 90 degree elbows/fittings in your loop as it will become very restrictive if you use too many. 45 degree fittings are the best.
Iapetos
Zephyranthes
  #145 (permalink)
Old July 4, 2009, 03:00 PM
Beermaster's Avatar
I used TFC 45 degree fittings, they work really nice, same with TFC tubing as well
Grovian - *E4300@2.2ghz*Gigabyte DS3L*G.SKILL F2-6400CL5D-2GBNQ 3x1Gb*Sapphire HD4850 1GB*Raptor 75Gb*
Buggz - *E7200@2.9ghz*Asus P5Q*Patriot PC2-6400*eVGA 8800GTS 320gb*WD 160GB CaviarSE*
Lil-Grov Acer One*8gb SSD*WinXP pro
Tathar WIP*Q9550*Gigabyte EP45-UD3P*OCZ Reaper PC-8500 4gbX2*OCZ Vertex 120gb*WD 1TB WD1001FALS*BFG GTX275*
  #146 (permalink)
Old July 4, 2009, 08:03 PM
everything's working well, got my cpu to 3.6GHz :)
Now for my gpu lol. I use ATi Tray Tools (latest beta).
  #147 (permalink)
Old July 4, 2009, 09:27 PM
Excellent! Keep going!
Iapetos
Zephyranthes
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
