  #131 (permalink)
Old July 3, 2009, 02:49 PM
Jackquelegs's Avatar
Check that you have tightened the barbs to the blocks. Occasionally the torque from the tubing will loosen the barbs.
Also, re-do the clamps, sometimes that helps
Iapetos
Zephyranthes
  #132 (permalink)
Old July 3, 2009, 03:13 PM
So I got it to work. Currently on my first hour lol. Thanks guys. So I should refill it when it goes below 3/4 right? Do I leave the cap on the top of the res? How does the air bubble leave? Do I need the top of it open to let the air out or does it just let more air in that way? Thanks again.
  #133 (permalink)
Old July 3, 2009, 03:34 PM
MpG's Avatar
MpG MpG is offline
Technically speaking, the air doesn't need to 'leave' the reservoir. All that needs to happen is for the air to move to the top of the res, while the water moves into the loop. Equal volumes are exchanged when that happens, so you can leave the cap on, except for when you're filling the loop. You may hear a faint 'hiss' when you unscrew the cap, because of a slight pressure buildup as the system warms up, but it won't interfere with the bleeding process.
  #134 (permalink)
Old July 3, 2009, 03:58 PM
so I should bleed it every 6-8 months?
Vid:
YouTube - My Water Cooling setup
How do I make it 720p?
  #135 (permalink)
Old July 3, 2009, 05:25 PM
Once it's bled it should be fine. Depending on what you use as coolant, you should take it apart to clean every year or so.
Iapetos
Zephyranthes
  #136 (permalink)
Old July 3, 2009, 05:54 PM
You're making it sound like it needs to be bled after the test lol.
  #137 (permalink)
Old July 3, 2009, 06:22 PM
http://i300.photobucket.com/albums/n...d/100_1009.jpg
Is it supposed to fog like that?
http://i300.photobucket.com/albums/n...erlord/006.jpg
far away pic.
  #138 (permalink)
Old July 3, 2009, 06:39 PM
Yeah that's the heated water evaporating. It's fine.
Iapetos
Zephyranthes
  #139 (permalink)
Old July 3, 2009, 07:56 PM
Cool so I never have to uncap the res to let it out? I'm going to be on my 8th hour in a minute W00t!. I'll leave it overnight lol, it hasn't leaked so far. Well sometime in the Fall-Winter I hope to upgrade to a whole never CPU socket and Ram, I can bleed the system then. I feel like the Home Depot tubing is average at best. What would be some good tubing to use? Don't care what price and what company. And bitspower for 90/45 degree barbs correct?
  #140 (permalink)
Old July 4, 2009, 12:02 PM
SugarJ's Avatar
Bitspower makes the best barbs and fittings out there, IMHO. And I like my Primochill tubing, but Feser is nicer (more opaque).
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
