  #121 (permalink)
Old July 2, 2009, 02:13 PM
Jackquelegs's Avatar
For sure. Do check on PerformancePC. They're great on fittings.
Bitspower Fittings : Performance-PCs.com, ... sleeve it and they will come
I think you'll find what you like in there
Iapetos
Zephyranthes
  #122 (permalink)
Old July 2, 2009, 08:32 PM
Disregard my last post, I'm almost done. Does the pump vibrate ennough that it will move around in the case? I have it adhesive taped to a mini stand which is not held.
  #123 (permalink)
Old July 2, 2009, 08:44 PM
ChuckleBrother's Avatar
I would bolt it down in addition to using the adhesive pad that came with it. Not necessary at ALL, if you put it on once it will be tough as hell to get it back off again, but hey, better safe than sorry am I right? If you don't have accessible screw holes just use the pad.
"...you play a mean banjo"
  #124 (permalink)
Old July 2, 2009, 09:03 PM
well I have it elevated on a metal box thing (that metal box thing is not bolted at all).
  #125 (permalink)
Old July 2, 2009, 10:08 PM
MpG's Avatar
MpG MpG is offline
Personally, I wouldn't bolt it down unless it's absolutely necessary. The bolts are just one more way the pump's vibration can get through to the case. And as long as there's no sideways pressure, the tubing is often enough to keep the pump from going anywhere.
  #126 (permalink)
Old July 2, 2009, 10:16 PM
FFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUU ran out of Clamps, need some moar
I'll get some tommarrow morning. Over the next year or so I need to learn what elbows and tubing is good for WCing since it is the cause of 90% of the problems (almost done, what's I get the clamps I can go to leak testing).
pics:
http://i300.photobucket.com/albums/n...d/DSCF2867.jpg
http://i300.photobucket.com/albums/n...d/DSCF2868.jpg
Now for my concern with the pump:
http://i300.photobucket.com/albums/n...d/DSCF2869.jpg
http://i300.photobucket.com/albums/n...d/DSCF2872.jpg
See how the adhesive tape is pasted to the metal box thing? But there is nothing to keep the metal box thing still or bolted (might need to drill some holes). I am using it to elevate the pump for easier connection.
  #127 (permalink)
Old July 2, 2009, 11:33 PM
MpG's Avatar
MpG MpG is offline
What if you switched the tube routing around a little? Have the pump outlet go directly into the CPU block, then down to the radiator? That should let you route the tubing in and out of the pump without any immediate tubing bends, which would let the tubing hold the pump where it is.
This photo's a little fuzzy, but it illustrates a little of what I'm talking about. Basically, there's absolutely nothing holding the pump steady here, except for the tubing connected to it. Based on your case photos, I'm pretty sure you could do something similar.
Attachment 6365
  #128 (permalink)
Old July 3, 2009, 09:14 AM
SugarJ's Avatar
Put some foam under that box. It will probably vibrate like hell on your metal case.
  #129 (permalink)
Old July 3, 2009, 01:18 PM
I keep getting leaks from the cpu block. Everything seems fine, could it be the Home Depot Tubing?
  #130 (permalink)
Old July 3, 2009, 01:42 PM
MpG's Avatar
MpG MpG is offline
As long as the clamps are tightened down properly, that shouldn't be an issue. I can't tell from the photo, but which barbs are you using? Because of the recessed holes in the block, sometimes the o-rings aren't compressed properly.
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
