  #101 (permalink)
Old June 30, 2009, 01:12 PM
Sadasius's Avatar
Originally Posted by Z Overlord View Post
how do I run it? (Credit info was changed recently) NCIX's UI is so strange.
They do. You will have to wait till they verify everything and process your order. If they cannot process it they will let you know why.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
  #102 (permalink)
Old June 30, 2009, 04:13 PM
So what Kind of screws do I need for my swiftech dual rad? I can't get the fans on X_X
And if the rad is upside down or up it doesn't matter right?
  #103 (permalink)
Old June 30, 2009, 04:31 PM
MpG's Avatar
MpG MpG is offline
The screws included with the radiator should work. If they weren't included for some reason, I believe the size is 6-32. You'll want 1 1/4" length for 25mm fans - any longer and you'll puncture a radiator tube.
  #104 (permalink)
Old June 30, 2009, 05:58 PM
anyone know of a method to mount the rad in the drive bay area? I can't figure it out.
  #105 (permalink)
Old June 30, 2009, 06:05 PM
SugarJ's Avatar
Originally Posted by SugarJ View Post
Z, take a look at this thread. http://www.hardwarecanucks.com/forum...c-project.html Page 5 shows how I made the brackets to mount the rad in the drive cage. Should be the same idea for you in the 1200.
Look at Page 5. I made brackets is about 10 minutes, or you can find something at Home Depot or Lowe's you can mod.
  #106 (permalink)
Old June 30, 2009, 11:00 PM
Okay, got it to mount by modding the front panel case. Now, will putting the res. above the psu heat it up? I might do that (don't see any other p[lace to put it lol). Maybe screw it into the case brackets (it'll still touch the psu).
  #107 (permalink)
Old June 30, 2009, 11:11 PM
MpG's Avatar
MpG MpG is offline
That's a non-issue. Acrylic isn't a very good heat conductor, so there won't be any problem with heating.
  #108 (permalink)
Old June 30, 2009, 11:19 PM
and why are the Noctua Fans magnetic? Aren't they bad for HDDs? I mean, their back is facing towards my MoBo (I have yet to reinstall) Could this be bad? The back has the magnets BTW.
  #109 (permalink)
Old June 30, 2009, 11:30 PM
MpG's Avatar
MpG MpG is offline
The bearings are magnetic. You can check out their company webpage for a more detailed explanation, but in brief, the magnetic fields are very localized, and only used to minimize motor friction and noise. So no need to worry about that.
  #110 (permalink)
Old July 1, 2009, 12:03 AM
K, just need to tube it and then fill it with water, I hope I didn't puncture the rad lol. I'll make sure to leak test to (do you really need to do it for 24 hours? Seems like overkill lol, but if that's what it takes...)
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
