  #91 (permalink)
Old June 28, 2009, 05:53 PM
From Dazmode's guide
Time to fill the loop, for that you will need an external power supply source to run your pump as you can not power up your system without proper CPU cooling. I used external IDE harddrive docking station or I could use other PC to "borrow" molex power connector from it.
No is that the big 20-24 pin thing that plugs into the Mobo? Do I need to mod it?
and how do I know how much liquid to put in the loop? With all the tubing the liquid needed will exceed the capacity of the res.
  #92 (permalink)
Old June 29, 2009, 08:56 AM
SugarJ's Avatar
A molex is the standard 4-pin connector. See wikipedia for pics. And you need to jump the PSU with a paperclip on the 24 pin, between the green wire and any black wire. You then control the PSU with the switch on the back. Do not have any of your other components plugged in other than the pump.
Fill your res, start the pump, shut down when res is empty. Repeat as necessary.
  #93 (permalink)
Old June 29, 2009, 01:58 PM
Any idea where I should put the resovior? I have an Antec 1200 case
  #94 (permalink)
Old June 29, 2009, 02:04 PM
Dazmode's Avatar
Above the pump.
Orange Build: Final Video
HTPC Build: Final Video
  #95 (permalink)
Old June 29, 2009, 05:27 PM
I meant like mounting it. I don't seem to know where to mount it.
  #96 (permalink)
Old June 29, 2009, 05:39 PM
Dazmode's Avatar
It up to you really. I've seen res hanging on pipes, res screwed to the case, res attached to the case with self-adhesive tape... whatever works.
  #97 (permalink)
Old June 29, 2009, 06:05 PM
Sadasius's Avatar
Before I mount mine I usually take it out for dinner and a movie.
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
  #98 (permalink)
Old June 30, 2009, 10:47 AM
Unhappy
uh, did my NCIXUS order go through? I don't think it did x_x
[IMG]http://i300.photobucket.com/albums/n...Untitled-8.jpg[/IMG]
  #99 (permalink)
Old June 30, 2009, 11:15 AM
ChuckleBrother's Avatar
Went through, just waiting for the credit card to be run through.
"...you play a mean banjo"
  #100 (permalink)
Old June 30, 2009, 12:40 PM
how do I run it? (Credit info was changed recently) NCIX's UI is so strange.
Tags
attempt , block , cooling , firts , water
First attempt at Overclocking my E8400 Mishtar Overclocking, Tweaking and Benchmarking 27 November 14, 2008 12:24 PM
First attempt at building a computer! fawconpunch New Builds 6 June 28, 2008 07:42 PM
Water Cooling Attempt enaberif Water Cooling 13 February 18, 2008 05:35 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
First A64 OC Attempt only 2070Mhz??? BALISTX Overclocking, Tweaking and Benchmarking 23 August 10, 2007 11:22 AM
