Originally Posted by lowfat Well Core Temp says +20C when running 8 threads of Linpack. This is @ 4.8GHz, 239bclk w/ 1.3375V. It could be very well a bad mount but whoever build this thing (bought it from someone on the forums) didn't do a very good job on the mounting system. The head has 7-10mm of play in the mounting bracket. And the mounting holes themselves have a lot of play as well. So chances are the head isn't even sitting properly on the CPU.
As for prep I didn't take a picture but i did it very well. Removed socket hold down, erasered it all up. Erasered everything in the socket area (up to the edges of the CPU). Even did the vaseline in the socket. Then used 3 layers or insulation around the head. |
I am trying to remember what program I used for some kind of idea on temp on the cpu. Most programs will not read/show a negative number. I think Speedfan did at least show a negative temp indication. When running Prime95 I could see temps climb to 0C. Once above 0C, temp would quickly rise...then computer would freeze up.
239Mhz, 4.8Ghz...hell man turn on that turbo
for 5.0Ghz!
Choo Choo bitches, progress coming through.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy
