  #31 (permalink)
Old December 25, 2009, 04:08 PM
lowfat's Avatar
Finally back up
The last board I bought was a POS and couldn't overclock worth a damn. Finally got a decent board a few weeks back and since I was testing the ioXtreme for a while I didn't have the time to throw it back on phase.
Mael
Big Lian Li
Forever Alone
  #32 (permalink)
Old December 26, 2009, 07:38 AM
gingerbee's Avatar
nice ud7@4.8 what temps? wow
  #33 (permalink)
Old December 26, 2009, 10:01 AM
lowfat's Avatar
According to Core Temp around 20C under linpack.
Mael
Big Lian Li
Forever Alone
  #34 (permalink)
Old December 27, 2009, 09:23 AM
LionRed's Avatar
+20C? or -20C?
Any pics Lowfat..would be nice to see your prep for sub zero temps.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
  #35 (permalink)
Old December 27, 2009, 10:17 AM
lowfat's Avatar
Originally Posted by LionRed View Post
+20C? or -20C?
Well Core Temp says +20C when running 8 threads of Linpack. This is @ 4.8GHz, 235bclk w/ 1.3375V. It could be very well a bad mount but whoever build this thing (bought it from someone on the forums) didn't do a very good job on the mounting system. The head has 7-10mm of play in the mounting bracket. And the mounting holes themselves have a lot of play as well. So chances are the head isn't even sitting properly on the CPU.
As for prep I didn't take a picture but i did it very well. Removed socket hold down, erasered it all up. Erasered everything in the socket area (up to the edges of the CPU). Even did the vaseline in the socket. Then used 3 layers or insulation around the head.
Mael
Big Lian Li
Forever Alone
  #36 (permalink)
Old December 27, 2009, 10:56 AM
chrisk's Avatar
Folding Captain
I saw your 4.8GHZ clock in your sig yesterday Lowfat and wondered how you did it. I found watercooling to be an adventure for me so this phase cooling is pretty nuts.
The specs on that rig are impressive with the ioXtreme (pity the rig can't fold bigadvs yet ;) )
Fold for team #54196
  #37 (permalink)
Old December 27, 2009, 11:28 AM
Is the cooling tube running around the bottom of your case and then onto the CPU or does it go through the case?
  #38 (permalink)
Old December 27, 2009, 12:26 PM
lowfat's Avatar
I don't know if i fully understand your question so I'll just post a pic.
It goes out where the rear exhaust fan is.
Mael
Big Lian Li
Forever Alone
  #39 (permalink)
Old December 27, 2009, 01:31 PM
gingerbee's Avatar
cool setup man i want one so bad thank for the pic
  #40 (permalink)
Old December 27, 2009, 03:13 PM
kendallcschm's Avatar
why did you put Vaseline on the cpu!?!?! what does it do
Custom Water Cooling Setup BALISTX Water Cooling 37 July 29, 2008 10:02 PM
Need help with first water cooling setup. BALISTX Water Cooling 18 March 23, 2008 10:11 PM
Water Cooling Setup Overview Sting3r11 Water Cooling 10 November 28, 2007 09:52 PM
First water cooling setup. jubeix Water Cooling 6 November 16, 2007 07:22 PM
Anyone looking for help with a water cooling setup, please post here Misoprostol Water Cooling 75 September 17, 2007 11:09 AM
