-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   EK is going to release EVGA Classified full cover chipset block (https://www.hardwarecanucks.com/forum/water-cooling/18540-ek-going-release-evga-classified-full-cover-chipset-block.html)
Dazmode June 2, 2009 05:30 PM
You guys likely have already read that EK made single block for EVGA Classified chipset/mosfet motherboard.
This is realy nice, makes me want to have his mobo. Just 2 water connections instead of 6 for my Gigabyte.:sad:
Here is pricing if anybody interested.
3830046991416 EK-FB EVGA X58 CLASSIFIED Plexi+Nickel USD 129,95
3830046991423 EK-FB EVGA X58 CLASSIFIED Acetal+Nickel USD 139,95
Here is prototype:
http://www.dazmode.com/_image/TEMP/E...-Prototype.jpg
MpG June 2, 2009 05:44 PM
The one-piece design is nice, but I think I like EVGA's solution better, with the NB and SB flow paths in parallel with each other. Even with the NF200, you don't need insane cooling on the SB area, and blocks like this EK design create more flow restriction than a chipset block should have.
Sadasius June 10, 2009 03:29 PM
Damn first I heard of this..... Neat idea though. Makes it so much easier for tube routing.
kruzn4evr June 11, 2009 06:07 AM
I would tend to agree with MpG.... and I wouldn't go with the one pictured though, me thinks its fugly..lol...might not be too bad as a separate loop with a mcr120-qp-res rad though, a nice simple easy way to WC mofset/nb/sb.
donkon June 15, 2009 11:02 AM
Well this is how the red/black one looks: (found it on another forum)
http://www.xtremesystems.org/forums/...1&d=1243281481
Sadasius June 15, 2009 12:33 PM
Damn that looks good. Eddy is really upping his game I see.
Dazmode June 15, 2009 06:52 PM
It is not red in final version.
FtGF June 15, 2009 09:55 PM
That block totally kills the boards sexiness. :sad:
Sadasius June 16, 2009 05:26 AM
Well that depends on what parts you think were sexy to begin with. Things can be done to a motherboard to dress it back up again. The EK block you can throw some red LED's in the 'classfied' link part of the block assembly to make it stand out and video cards won't hide it. Plus if you use the Dominator Airflow RAM cooler from the GT series that is black and red and take out the stock fans and put in red LED one's then I think your sexiness would be back. :thumb:
MpG June 16, 2009 07:23 AM
Granted, it's a matter of taste. But personally, acrylic and copper doesn't mesh with the Classified's red. An acetal top would work better in this case, imo. But even that kind of kills the lines that the stock heatsink gives the board.
