Old May 31, 2009, 10:34 AM
Cowboy's Avatar
Default Questions about push/pull
Would a single 120mm blackice GT rad cool better in a either a push or pull? what about push + pull?
Would the added fans/effort be worth it?
Same question applies to my swiftech 2x120mm rad
Old May 31, 2009, 11:04 AM
Dazmode's Avatar
Feser recommends pull for single fan, probably the same applies to other brands. You also can sandwich fans in push/pull around your rad. Rather important to use rubber sealing mat between fan and rad.
Orange Build: Final Video
HTPC Build: Final Video
Old May 31, 2009, 11:06 AM
Cowboy's Avatar
hmm, and where and how much would these rubber sealing mats cost?
I'm already way overbudget for this watercooling adventure of mine... I should have quit at 200 bucks spent.
Old May 31, 2009, 11:14 AM
sswilson's Avatar
Just go down to the hardware store and get some of that black foam they sell for sealing doorframes and cut it to size.
Old May 31, 2009, 11:17 AM
Cowboy's Avatar
Is it REALLY important that I have this? is it worth the hassle?
Old May 31, 2009, 11:18 AM
sswilson's Avatar
I only bothered with it for my PA120 because of the smaller outer surface area. On my 220 & 320 rads I just slapped the fans directly onto the rad.
Old May 31, 2009, 11:20 AM
Cowboy's Avatar
Alright. I guess I'll skip it then. seems like a huge pain in the butt.
Since I've got some extra fans I think I'll go push/pull. Thanks.
Old May 31, 2009, 11:35 AM
gingerbee's Avatar
that's the way I flow just put the fans on as long as there good then so are you.and if your gonna use the foam just get it from the hardware store like sswilson says.
Old May 31, 2009, 12:01 PM
Dazmode's Avatar
Don't those mats are supplied with rad? Separately they are about $5.50 ....If you don't have them no biggie.. all depends how anal you are... ha-ha...
Old May 31, 2009, 01:08 PM
kyle_L's Avatar
how much of a difference will those mats make.
im looking for work.
Push/Pull on S1283 nckid4u Air Cooling 11 April 26, 2009 10:09 AM
TRUE Push / Pull Question rjbarker Air Cooling 12 March 21, 2009 11:54 PM
How do you like my new rad? Push-Pull FTW!!! Sniper Water Cooling 26 December 8, 2008 08:09 AM
Fans for Push/Pull on PA120.2 Supergrover Water Cooling 20 September 14, 2008 07:18 PM
Push vs Pull on a Rad? Supergrover Water Cooling 10 October 16, 2007 07:13 PM
