Old May 30, 2009, 03:45 PM
gingerbee's Avatar
Default recommend water blocks
ok i have an extra gtz just wonder if there's anything new i might be missing that's better have to replace tt block it's gonna leak soon i can see the fluid slowly pushing it's way out so i need a new one.
Old May 30, 2009, 03:52 PM
Dazmode's Avatar
Best bung on a buck is Supreme LT. Price of GTZ with performance just under K350 without restriction. You can not beat this.
...Or you can try to get Heat Killer from USA seller. I'm standing in line, but manufacturer backlogged for 3-4 months...
P.S. I have Supreme (original) Acetal from my blocks round up test. E-mail me if interested. Looks drop dead gorgeous.
Orange Build: Final Video
HTPC Build: Final Video
Old May 30, 2009, 04:02 PM
gingerbee's Avatar
thanks daz gonna check it out
Old May 30, 2009, 05:37 PM
MpG's Avatar
MpG MpG is offline
If you have a GTZ already, I wouldn't waste money on another block. I have yet to see a well-organized review that puts the gap between the various top-tier waterblocks at more than a couple of degrees.
Is the backlog for the HK's that bad? Damn, I was just casually browsing Sidewinder about half a month ago, and saw the Cu version in stock, so I ordered it, and it was shipped without any trouble.
Old May 30, 2009, 06:38 PM
Dazmode's Avatar
True. But 2 degrees here, other two there ... it adds up. My personal quest is for silence, so I have to have the best blocks and bigger rads to get to lowest rpms ...
Sidewinder the only dealer at the moment. They don't sign new partners as they can't make enough for all...
Old May 30, 2009, 11:02 PM
MpG's Avatar
MpG MpG is offline
Don't get me wrong, I WANT those two degrees. I'll take one degree, in fact. But that's really not everyone's approach, and he said that he already had the GTZ block.
Old May 31, 2009, 05:36 AM
gingerbee's Avatar
i will be using the gtz for a little while until i can afford a new block thank.( the way i run things is to always have extra which means i won't have an extra block anymore so i will need a new one)
Old June 10, 2009, 03:23 PM
Sadasius's Avatar
Huh?!? Only dealer for what?
Water Blocks - CPU : Performance-PCs.com, ... sleeve it and they will come
Black Phoenix CPU-Z Validation
Code:
 Q9650 @ 4.05 Ghz (9x450) / 4 GB DDR3 1600 Crucial Ballistix @ 1800 Mhz / 3870X2 / Ultra X3 1000/Maximus Extreme X38 / Thermaltake Xaser VI custom watercooled with black powdercoat. Click above for pic!
San Ace Awesomeness!
San Ace Awesomeness Part II!
Old June 10, 2009, 03:39 PM
Dazmode's Avatar
So, there is more now... I still can't get trough.
Old June 10, 2009, 03:51 PM
Sadasius's Avatar
Yeah it's a hot item that is constantly sold out.
Code:
[FS] Rads, pumps, blocks, vid cards, water cooling extravaganza ect. Sniper Buy/Sell & Trade 186 May 1, 2009 08:17 PM
water blocks WolfBane Water Cooling 9 April 19, 2009 06:38 PM
WTB/WTTF: 8800 Ultra; also need 2 full cover water blocks (or kit) S_G Buy/Sell & Trade 11 December 23, 2008 12:28 PM
Are there any water blocks for HD4850 + HD4870? howdid Video Cards 14 July 26, 2008 08:08 AM
Koolance Geforce 8800 water blocks Forge Water Cooling 5 March 12, 2007 04:47 PM
