View Poll Results: Which color for Gigabyte Extreme X58 board?
Black/UV Blue 6 22.22%
White/UV Blue 12 44.44%
Acid Green 6 22.22%
Red 4 14.81%
Other ? 0 0%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Old May 26, 2009, 05:29 PM
Dazmode's Avatar
Default Tubing, tubing... what color to choose?
Finally got my hands on plenty of UV tubing... but the problem is which color to pick.
To my shame, I was blissfully unaware that Black, Silver and White tubes are actually glow Blue.
I never was for Red, but it looks so-o good as well as Acid Green.... From other hand for Gigabyte extreme mobo, Blue can good too.
Couple pictures below. UV colors look more milky then they are (couldn't get proper picture in spite all my attempts).
Orange Build: Final Video
HTPC Build: Final Video
Old May 26, 2009, 09:39 PM
JD JD is offline
White/UV Blue would match the best with the board IMO.
Black/UV Blue could work too I guess. Not a big fan of green/red though.
Old May 26, 2009, 10:46 PM
ChuckleBrother's Avatar
Yeah I voted white, looks so clean and awesome. Not sure how flexy it is though, I have a couple feet of Feser 3/8 - 1/2 and it's sort of stiff and unyielding, but I assume you have that bit under control
"...you play a mean banjo"
Old May 27, 2009, 08:25 AM
Dazmode's Avatar
It doesn't feel any stiffer then Tygon. White is in 3/8 size , so it will be even easier then 1/2.
As for routing, I decided l go with 45 degree and straight compression fittings for few reasons:
1) The cost is no more then barbs (Swiftech polished barb - $7 vs. Feser compression straight - $6);
2) I'm sure they will last forever, so this is one time cost;
3) Less bending of tubing: no kink, less tube, cleaner look;
4) Worm clamps look ugly;
5) Chipset/MOSFET/CPU blocks are too close for 180 degree turns anyway;
6) This is my hobby, so I want it nice looking not for a "check mark".
Old May 27, 2009, 11:07 AM
gingerbee's Avatar
i really don't care about color but i guess white
Old May 27, 2009, 12:49 PM
Match your board. My board has black/green so I went with painting my case black and green tubing.
Old May 28, 2009, 12:05 PM
Dazmode's Avatar
Thank to all who took care to provide feedback. I was inclined to white already...
Old May 28, 2009, 01:04 PM
Remember: pics at the end or we lynch you
Old May 28, 2009, 09:15 PM
Dazmode's Avatar
Promise
Old June 9, 2009, 03:24 PM
magictorch's Avatar
I'd go with white too for your system.
I just bought some red feser tubing from your store and it really is a very rich red, quite impressed-will look nice in a white MM horizon.
shiny white tubing? magictorch Water Cooling 12 April 22, 2009 01:20 PM
Tubing and Tube Coils miggs78 Water Cooling 21 August 16, 2008 06:51 PM
Cutting tubing elninio Water Cooling 11 June 10, 2008 04:14 PM
Fans for WC and tubing Dashock Water Cooling 7 May 5, 2008 10:13 AM
Tygon tubing Dark Water Cooling 5 December 28, 2007 08:42 AM
