Old May 25, 2009, 05:59 AM
Synth's Avatar
Default Radiator advice needed ..
Alright guys, I have a Cosmos 1000 case, with the 2x 140mm fan holes up top.
Now for the same price, I can either buy an XSPC RX360 (3x120mm) or a Black Ice GTX 280 (2x 140mm).
Obviously, the Black Ice will fit with no mods. The XSPC, however will probably only draw fresh air from 2 fans and require minor mods for optimal 2 fan cooling or hardcore mods for 3 fan cooling.
Wondering what I should buy.
By the way, I am trying to cool down a Q9550, a GTX260 and a P35 northbridge.
Cheers!
Old May 25, 2009, 06:29 AM
sswilson's Avatar
My own personal experience would suggest that the 2 X 140mm would be the best bet. Since I was only able to get push/pull on half of a swiftech 2 X 120mm, I'd think that the larger cooling area of the 140mm would make up some of the loss.
Old May 25, 2009, 07:27 AM
Varroa's Avatar
The holes on the top of the 1000 are not standard so you will only be able to mount the rad to one set of fan holes. For example, a 2x120 or 2x140 rad will only mount to one of the fan holes but that is more than enough. I have a 2x120 uptop and it works fine. I end up cutting out the stamped grills and also doing some modes to the plastic cover to allow more air flow.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old May 25, 2009, 08:16 AM
Synth's Avatar
I am currently using a Swiftech MCR220, up-top. I know the 2x120mm can only be attached via 1 fan, which is sufficient fold holding.
But are you sure the 2x140mm doesn't attach properly with 2 fans? I was under the impression it did...
Old May 25, 2009, 08:25 AM
Dazmode's Avatar
Off topic, but why not Feser 240? Are those two much less then $115CND?
IMHO bigger fans in smaller rad will cause loss of performance. You supposed to use silicon pads to seal assembly off to max airflow.
EDIT: Sorry misread the post. The larger surface wins: between 3x120 and 2 x140.
Orange Build: Final Video
HTPC Build: Final Video
Old May 25, 2009, 08:35 AM
daz, do you actually have these in stock? i didn't think anybody in canada had them...
Old May 25, 2009, 08:39 AM
Dazmode's Avatar
I don't want to get banned ...
I do have all types including MONSTA
. Just arrived last week.
Old May 25, 2009, 11:47 AM
MpG's Avatar
MpG MpG is offline
I think you might want to look at the 140mm rad, since the C1000 holes aren't properly aligned for a 120mm rad. The 120x3 rad has a slightly larger surface area, but that will be offset by the lack of fans on the third section. Plus, you'll likely get a better seal against the rad using the 140mm fans.
Old May 25, 2009, 04:42 PM
ChuckleBrother's Avatar
I'd also go with the dual 140mm rad, should get better flow, pressure, everything, all with that better seal. The only thing I would be sure of is to make very very sure of what sort of CFM range that rad likes to make sure that your fans can deliver.
"...you play a mean banjo"
Will extra radiator be needed? Bluefusion Water Cooling 12 February 13, 2009 11:51 PM
Some advice needed please! D4ng3r Cases 5 December 9, 2008 11:45 AM
Advice needed on WC Jackquelegs Water Cooling 36 November 22, 2008 10:40 PM
Advice on loop needed ... Synth Water Cooling 8 May 9, 2008 05:31 AM
Advice on mobo needed badly 999Virus999 CPU's and Motherboards 8 January 11, 2008 10:23 PM
