-   -   water cooled q9650 temps (http://www.hardwarecanucks.com/forum/water-cooling/18190-water-cooled-q9650-temps.html)
bc_tileguy May 23, 2009 10:06 AM
does 49-50 c full load sound about right (q9650 at 4.2)
thermolchill 120.3+120.1+ dtek fusion v2
i have a quad nozzle should i install it ? or will it kill my flow ?
what do you guys think
thanks
CanadaRox May 23, 2009 04:02 PM
Those temps sound fine to me. Don't use the quad nozzle as it only improves the temperature on 65nm quads, the die size of 45nm is smaller so the high pressure areas actually miss the die. IIRC, the best size to use with 45nm quads is the 4.5mm nozzle from the V1 (works with the V2 as well).
MpG May 23, 2009 07:55 PM
^^^ Seconded ^^^
Temps are right where they should be, I'd say. And the quad nozzle has a lousy track record with the 45nm procs.
bc_tileguy May 23, 2009 11:34 PM
:biggrin:ok thanks guys
