-   Water Cooling (https://www.hardwarecanucks.com/forum/water-cooling/)
-   -   anyone with watercooled hd 4890's ? (https://www.hardwarecanucks.com/forum/water-cooling/18188-anyone-watercooled-hd-4890s.html)
bc_tileguy May 23, 2009 09:36 AM
hi there just wondering if there is anyone on these forums with water cooled 4890's (full coverage block)
can you please post your before and after temps please
and your water cooling parts used
thanks:biggrin:
bc_tileguy May 23, 2009 11:56 PM
just finished installing both blocks
NCIX.com - Buy Ek Water Blocks EK-FC4890 CF Nickel Full Cover Radeon HD 4890 GPU Block G1/4 - No Barbs - 3830046993847 In Canada.
i have results
air cooled idle =60c load 80
water idle =30c load 37
overclocking has improved
both cards can run at 980/1150(water) on air they max out at 950/1100 (at 80 % fan speed) (holly shit LOUD!!:sad:)
its so much quieter now:thumb:
i will post pics soon
and benchmarks to fallow:clap:
X9999 May 31, 2009 06:41 PM
XSPC Razor 4890 block
Idle Temps GPU-Z
GPU - 34 C
Mem - 39 C
VRM - 47 C
Load Temps GPU-Z
GPU - 39 C
Mem - 47 C
VRM - 68 - 78 C 78C on Crysis
Single Loop Q6600 3.2GHz XFX 4890 950/1000 MCR320-QP, MCP655, XSPC Razor 4890 and Swiftech Apogee GTZ.
ra1d May 31, 2009 10:30 PM
I've got the PowerColor 4890 LCS which idles at 32C with a load temp of 40C
stalker July 9, 2009 06:32 PM
Hi... I'm hoping you'll still post some pics!
I'm also interested in that block... well, the acetal covered one.
If you decide to post some pics, could you please take some close shots of the memory and vrm's to see how well it fits them. I wonder, would it be possible to put ceramic paste instead of thermal tape?
Cowboy July 9, 2009 06:37 PM
I have the Koolance vid-487 and I got idle temps of 28C and load temps within the mid 30's
Hope it helps. That koolance block is a monster.
Dazmode July 9, 2009 07:25 PM
Swiftech also claims their 4870 block fits 4890.
stalker July 12, 2009 04:10 AM
Thanks!... but the blocks that you mentioned are not accessible to me. The only real shop that sells pc water cooling parts has only EK full cover blocks and that's why I'm interested in that model with the same vga card.
I wanted to see the clearance between the ram chips and vrm and the block's base.
Varroa July 12, 2009 06:53 AM
Koolance blocks
1 Attachment(s)
I have the Koolance vid-487 block using the same pads that were on my old 4870. These are my idle temps and my room temp is 26c right now. Load temps are around 10c higher across the board. This is cooled by a swiftech 2.120 rad using two Noctua fans at 1/2 speed. My P35 Northbridge is also on the same loop but that is all. Noticed that my VDDCs get to 110c during fur mark so I reseated my block and now they only hit about 100c in furmark. There is something wrong but I can't figure it out.
Attachment 6500
Varroa July 12, 2009 08:15 AM
Very strange, just ran Fallout 3 on ultra high settings at 1680x1050 and my GPU, mem and VDDC all stayed at about the same temps as idle (+/- 2 degrees). Does Furmark really push your card that much? I am going to load up Crysis and see what I get:
Crysis temps: GPU highest was about 47c, Mem about same and the highest VDDCs was 61c. All on high settings at 1680x1050. I guess Furmark REALLY pushes your video card more than any game will.
