Old July 8, 2007, 01:47 PM
Misoprostol
Guest
Posts: n/a
Honestly at the end of the day, I ended up with the Danger Den block in my system.
The other two blocks give better temps, but I really like being able to use the slot next to my graphics card, and the tubing routing is so easy with the SLI-ready fittings.
As for the EK block. It arrived too late to be included in the round up. Maybe next generation I will get one earlier and can include it in an 8900 GPU block round up. :(
I could probably get one now and test it against just the Danger Den, but I'm working on a couple other things atm.
Old July 8, 2007, 03:39 PM
Patriote's Avatar
Sounds good! Looking forward for those other things
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old July 9, 2007, 11:24 PM
lowfat's Avatar
Installed my Fuzion GFX today, and i am very impressed. 39C idle, and 41C load :)
Old July 10, 2007, 10:15 AM
Misoprostol
Guest
Posts: n/a
That seems to be pretty in line with my results. :)
Glad you like it.
Old July 10, 2007, 02:28 PM
lowfat's Avatar
I forgot how much water helps :) I haven't W/C'ed a GPU since a 9700 Pro.
Old July 17, 2007, 05:33 PM
JayDee
Guest
Posts: n/a
Hey Misoprostol (or anyone else that has used the D-Tek GPU block) I was wondering if you used the thermal pad that comes with the D-Tek? I normally just ignore thermal pads but it seems as if it could actually be useful here as it will increase the surface area contact between the block and GPU. I looked on the D-Tek site but the site is pretty basic.
For those who don't have the D-Tek see the pic of the thermal pad and block. The pad fits around the blocks copper contact area and should create more contact with the GPU.
Old July 17, 2007, 05:40 PM
Misoprostol
Guest
Posts: n/a
oops
Even ninjas make errors from time to time. I did forget to use that thing. Honestly I wouldn't expect it to make a huge difference, but in this case, the FuZion already won, so it's not like D-TEK's gonna call me on the phone and say "Hey it lost because you didn't use the thermal pad" but D-TEK does recommend using that thing. It's kinda a neat little thing. It recently showed up on NCIX.com as a standalone product. Not in stock yet, but apparently coming in 2-3 weeks...
Old July 17, 2007, 06:01 PM
JayDee
Guest
Posts: n/a
oops
Cool! Thanks Misoprostol.
  #19 (permalink)
Old July 17, 2007, 06:22 PM
Apollo4g's Avatar
My EK gives my 8800GTS idles of 38C and loads of 41C and this is with a 640/2040 OC. Im very happy with it.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Discussion Thread for Koolance CPU-330 review Misoprostol Water Cooling 35 April 20, 2008 05:23 PM
Antec TPQ Problems Discussion Thread enaberif Power Supplies 27 March 13, 2008 04:10 PM
Phenom Preview Discussion Thread Misoprostol CPU's and Motherboards 34 December 14, 2007 01:00 AM
Thermalright XWB-1 Review Discussion Thread Misoprostol Water Cooling 11 October 25, 2007 07:53 PM
Discussion thread for QNAP TS-201 review Misoprostol Storage 4 July 18, 2007 04:23 AM
