Old May 20, 2009, 07:46 AM
Default installing a Ek Water Blocks EK-FC4890 CF Nickel Full Cover Radeon HD 4890 GPU Block
Hi guy's has anyone installed this block yet ? is so can you give me some pointers please
thanks
Old May 20, 2009, 08:09 AM
magictorch's Avatar
I guess its like the other EK blocks. The things to avoid with those blocks are warping/shorting.
First of all (as a precaution) I recommend using flat, cardboard or plastic washers on the screws. You may not need them but there were strange shorting issues with the GTX 2 series blocks and the 4870 blocks-apparently unrelated to warping.
Secondly to avoid "warping/shorting" gently place the block onto the bare card so it just makes contact and spreads the thermal paste on the mem and GPU chip. Then screw in the 4 screws that cover the GPU chip so they just bite. After that add the other screws, again so they just bite. Now tighten the screws in sequence a little at a time (you dont need to tighten very much) and watch for warping-especially over the VRM area. You will also likely see a little bit of paste on the chips pushed to the edges if you look carefully. Should be good after that!
Old May 20, 2009, 05:08 PM
thanks for the reply magictorch
The ek 4890 block comes with thermal pads for the memory and vrm's and plastic standoffs for all the mounting screws .Do i still need washers for the screws ?
thanks
Old May 21, 2009, 05:09 PM
magictorch's Avatar
Plastic standoffs? It used to be good old metal on metal. They should work fine. BTW the EK blocks are incredibly effective-I only have a delta of about 4-6oc on the core and mem. during gaming.
Old May 23, 2009, 10:01 AM
what are your temps ?
Old July 7, 2009, 11:58 AM
Magictorch.. teacher we need a video plesh!!.. :D
Old July 7, 2009, 02:44 PM
Dazmode's Avatar
Not a Radeon, but it will give you some idea:
YouTube - Watercooling build Part9 - nVidia GTX285 PCB Ver.1 EK Waterblock installation
Orange Build: Final Video
HTPC Build: Final Video
Old July 7, 2009, 03:59 PM
Thanks for the video.. great set of videos you have there... Very nice :)
[WTB] Full Cover 9800GTX water block. Eatstone Buy/Sell & Trade 5 January 15, 2009 10:12 AM
WTB/WTTF: 8800 Ultra; also need 2 full cover water blocks (or kit) S_G Buy/Sell & Trade 11 December 23, 2008 01:28 PM
[Checking interest] FS: GTX 260 / GTX 280 XSPC Full Cover water blocks S_G Buy/Sell & Trade 4 November 15, 2008 04:34 PM
