  #41 (permalink)
Old May 28, 2009, 01:41 AM
aviduser's Avatar
Update:
Basically re-did the whole loop, installed the rad right side up. Mounted HDD's below to make room for tubing. Made a steel mounting plate for the apogee.
Load temp is 50C with a 1.45 vcore, its 5-7.5C lower than my true. The rad has 2 noctua p12's pulling. Much happier with the look of this loop. Will most likely add another mcr220 stacked, just have to find out if the temp dif. is worth the price.
Heres a pic of the new loop.
Moar pics here: http://www.hardwarecanucks.com/forum...tml#post201347
I5 4670K 4.4ghz - Gtx 780 Amp - 2x4 Corsair Vengeance - MSI z87-g43 - Tx 850w - Asus pbq278q
  #42 (permalink)
Old May 28, 2009, 10:02 AM
MpG's Avatar
MpG MpG is offline
Looking good. I'd be surprised if that pump wasn't making some vibration noise, but that's nothing that couldn't be solved with a little foam, if necessary. Nothing wrong with a second radiator, but the gains from the stacked haven't been looking too promising with single fans. Maybe if you threw another bank of fans onto the second rad as well? Regardless, not crucial if you're only cooling the processor. If you ever put the video card under water, then the improvements would be more noticeable.
  #43 (permalink)
Old May 28, 2009, 11:05 AM
Mattu's Avatar
i like the pump placement. it looks really clean
  #44 (permalink)
Old May 28, 2009, 11:52 AM
Dazmode's Avatar
Huge improvement with looks! First cut was a bit ugly
Orange Build: Final Video
HTPC Build: Final Video
  #45 (permalink)
Old May 30, 2009, 01:11 AM
aviduser's Avatar
Thanks for the comments!
You'd think the pump would be noisy, I've used some padded double sided tape and it actually isolates it really well. I can have the mcp655 wide open and its still very quiet. Been trying to get a higher OC, but my phenom II is really picky after 3.7 ghz, might just say screw it and stay there. It's probably a better price/performance decision than another rad.
Engineering Design Build killall-9 New Builds 5 April 29, 2009 12:21 PM
Software for Case Design. CMetaphor Cases 6 December 22, 2008 05:59 PM
Pump design. BrainEater Off Topic 3 June 20, 2008 05:47 AM
Opamps stage design questions trodas Audio 1 June 10, 2008 09:59 PM
Help design new rig. BALISTX CPU's and Motherboards 30 December 9, 2007 02:12 PM
