  #41 (permalink)
Old July 11, 2007, 07:25 PM
3.0charlie's Avatar
Nope, no problem here. No need for teflon tape, the o-ring will take care of the seal. When you'll install the barbs, just be careful to put too much torque on them. When you'll see the o-ring compressed, it's enough.
And always perform a 24hr leak check.
John
  #42 (permalink)
Old July 11, 2007, 07:31 PM
JayDee
Guest
Posts: n/a
Cool! Thanks 3.0charlie :)
While I was researching my H20 system I read that one guy recommended using Isopropyl alcohol in the system first to flush/clean out the system. I could see it also killing any organisims in the loop that might grow algae later on... I might try that.
  #43 (permalink)
Old July 11, 2007, 07:43 PM
sswilson's Avatar
John
I'll second and third that one!!!!!!
I suspect overtorquing the barbs into my TT CPU block (I know... don't laugh.... :) ) is ultimately what caused the acrylic top to crack and leak all over my old (fried) 1950pro.
  #44 (permalink)
Old July 11, 2007, 07:58 PM
3.0charlie's Avatar
Highly possible. As soon as you see the o-rings starting to compress, it's almost enough torque. There's hardly any pressure in a wc system. A lot of flow, but no pressure.
  #45 (permalink)
Old July 11, 2007, 08:05 PM
JayDee
Guest
Posts: n/a
From what I've seen I plan to tighten all the barbs by hand and then give them 1/2 turn with a wrench to finish.
  #46 (permalink)
Old July 11, 2007, 08:11 PM
3.0charlie's Avatar
Using the Swiftech barbs (plastic), I found that it's hand-torque + 1 turn. But since you'll be using metal barbs, it will be different. Probably less - 3/4 turn. Looking at the o-ring, you'll know when to stop.
John
  #47 (permalink)
Old July 11, 2007, 11:02 PM
Misoprostol
Guest
Posts: n/a
please do not use isopropyl alcohol in your loop. That is a terrible idea. It can break down reservoir glue, reduce the lifespan of O-rings and other nasty stuff.
As for how tight to do barbs, it depends on your blocks (I haven't bothered to read back). If you have Swiftech barbs, usually you can go ahead and crank them as tight as they'll go. Same with the FuZion. Danger Den blocks require you to ease up a bit but it's not a big deal
Basically what I do is I take a scrap of Tygon tubing put it over the barb and use that to grip it, then tighten it 'til I can't anymore. It's usually easy to get it tight enough that it will not come off.
  #48 (permalink)
Old July 12, 2007, 03:56 AM
JayDee
Guest
Posts: n/a
Thanks for that Misoprostol :)
*no Isopropyl*
I was only going to use it for an initial flush of the system and not for actual use in cooling it but I will avoid it :)
  #49 (permalink)
Old July 12, 2007, 04:55 AM
3.0charlie's Avatar
If you want to flush, just use distilled water first, then flush / fill with the coolant stuff.
On all barbs (including the DDs and Swiftechs), there is a hex nut (9/16" if I remember well) to torque it. I use that.
  #50 (permalink)
Old July 15, 2007, 03:48 AM
Apollo4g's Avatar
If you really want to clean your loop out, just mix a 10% viniger and 90% distilled water mix, then run it in your loop for a few hours.
Then flush it out 1-2 times with distilled water.
That will get all the "muuk" out of there.
I do it about once every 3 months.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Thinking About Watercooling - Where To Buy? ChuckleBrother Water Cooling 17 March 24, 2008 09:30 PM
Wishful thinking,... frosty Off Topic 13 December 12, 2007 03:25 AM
Supergrover's H2O Plunge Supergrover Case Mods, Worklog & Gallery 40 November 18, 2007 01:27 PM
thinking about a crossfire build the_bandit87 Video Cards 7 October 25, 2007 12:41 PM
OCZ taking over Babrbarossa Video Cards 7 December 8, 2006 05:56 PM
