Old May 11, 2009, 08:47 PM
Dazmode's Avatar
Default You get what you paid for?
I was really busy testing several waterblocks in last two weeks... As I have to drain the loop all the time I just went for Distilled water from Shoppers. Minerals: 0 ppm.
After some time I noticed that my tubing is not that shiny... so I blamed myself for munching stuff and touching tubes with dirty hands. Not quite.
As I moved to different set up from triple to dual rad, I had to change some tubing and figured out that I got quote a bit of crap inside my tubing.
Free lunch only in mousetrap?
Orange Build: Final Video
HTPC Build: Final Video
Old May 11, 2009, 08:49 PM
MpG's Avatar
MpG MpG is offline
Tygon tubing? Thermochill radiator?
Old May 11, 2009, 08:58 PM
Dazmode's Avatar
Feser360/Tugon tubing. I washed rad pretty good.
Old May 11, 2009, 11:57 PM
MpG's Avatar
MpG MpG is offline
Well, over a short period, Tygon generally goes cloudy no matter what.
Old May 12, 2009, 12:05 AM
I got MasterKleer tubing with distilled water and pt nuke and 0 problems :D
Old May 12, 2009, 12:31 AM
Chilly's Avatar
All tubing clouds eventually, it just matters on the cleanliness of all your internal parts(rad, blocks, etc).
I've personally never had *much* issue with clouding, I mean, yes, my tubing is a little clouded, but for the age of it(3-4yr old tubing), its fairly clean.
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Old May 12, 2009, 05:06 AM
CanadaRox's Avatar
There is also often some stuff inside the radiator that can cause the tubing to cloud faster if it isn't cleaned out.
Project: Black and White
Old May 12, 2009, 06:11 AM
bojangles's Avatar
After reading this I think I'm going to flush out my WCing parts before I even install it, just to be sure.
I'm thinking of going water cooling this summer.
Old May 12, 2009, 07:33 AM
Dazmode's Avatar
I want to retaliate that i did washed every single component, furthermore I did changed water several times (every time I put new CPU block on).
I think cheap water from the store is not that clean as it advertised. I probably could use tap water with same result.
Old May 12, 2009, 08:34 AM
JD JD is online now
I guess that seems reasonable but it should still be fairly clean if it's sold as distilled...
Though my Feser One also made my tubing cloudy but mine doesn't seem as bad as yours but it could just be your camera/lighting. And I use Primoflex ProLRT, not Tygon.
Final Build, Paid For, Now The Waiting Begins...! mlauzon New Builds 20 December 26, 2008 11:42 PM
You paid how much??!!??!! sswilson Off Topic 10 August 25, 2008 09:43 AM
