Old May 11, 2009, 09:17 AM
cork45's Avatar
Default Spec check
Hiya guys i'm about to buy a watercooling setup and i'd like to run it past you all first to be sure it's right.
Antec P182 || Antec Quattro 850w || Intel Q9550 || Coolit Domino ALC || Asus Rampage Formula || 2xHD4870 || 8GB G.Skill PC2-8000C5 || Samsung F1 1TB x4 || Bose Companion 5
Old May 11, 2009, 09:32 AM
it sond good to me, but dont forget to buy fan and 1/2 fithing(for rad and pump)
also i dont know if you can find ptnuke in ireland but it can be bether than pc ice
Old May 11, 2009, 09:41 AM
MpG's Avatar
MpG MpG is offline
Is that tubing by the foot or by the meter? 4 feet doesn't seem like enough. I've always budgeted twice the tubing that I think I'll need, because it's amazing how fast it gets used up, and there's nothing worse than having a build delayed because you were a foot or two short on tubing.
The clamps say they're for 1/2" tubing, which I think might be an issue. Odds are, the 1/2" refers to the outside diameter of the tubing, and your tubing has a 5/8" outside diameter.
Old May 11, 2009, 01:19 PM
Dazmode's Avatar
I don't see any fans. I'm also a bit vary from plastic clamps.
Orange Build: Final Video
HTPC Build: Final Video
Old May 11, 2009, 02:21 PM
ChuckleBrother's Avatar
I'd recommend metal fittings, no risk of over tightening and crushing the barbs. Otherwise, a triple is likely a LOT of overkill for just a cpu loop, not a bad idea though if you plan to watercool more in the future.
"...you play a mean banjo"
Old May 11, 2009, 02:53 PM
Sagath's Avatar
+1 for everything Chuck said. I'm using a triple rad for just an OC'd CPU and OC'd GPU, but I plan on upgrading to SLI, and even charlie will tell you a double will do 2xgpu and a cpu no problem.
You need good barbs (bitspower!), some fans (gelids!), and I prefer zap-straps for hose ties. Way easier to take off then those 'plastic clamps'. Either that or Worm-gears.
Other then that, it looks good. I really am happy with my Swiftech gear.
Old May 11, 2009, 03:01 PM
Dazmode's Avatar
GELID shows as poor performer in my radiator fans round up. They are better for case cooling not watercooling. Scythe fans were one of the top performing...
Old May 11, 2009, 03:30 PM
gingerbee's Avatar
do metal fitting so that you don't have to take them apart just to add them later later. which you'll want too
Old May 11, 2009, 03:37 PM
Metal Fittings for sure
Don't worry about hose clamps just use zip ties
Just use distilled water + pt nuke as its the cheapest solution and works well
That is a good top for the pump altho the only gripe I have about it is the outlet is on a slight incline and can make it tricky to work with.
Old May 11, 2009, 03:47 PM
I don't have any clamps at all,i just used 7/16 hose,by the time it cools down on 1/2 fittings its damn tight without them. The triple rads are overkill usually but they are nice for ultra quiet builds with low rpm fans.
Price Check for me!!!! Soultribunal Off Topic 4 April 21, 2009 02:54 PM
New i7 build spec help .... Dubravac New Builds 10 March 7, 2009 07:29 PM
Help needed on spec'ing a X58 build MrDisco New Builds 4 December 27, 2008 02:09 PM
9800 GX2 VS 3870 X2 (Price : Spec) Digital_Fortress Video Cards 15 May 18, 2008 07:26 PM
Check this out... 3.0charlie HardwareCanucks F@H Team 7 October 3, 2007 07:45 PM
