  #21 (permalink)
Old May 21, 2009, 08:46 PM
is there a specific way to mount the apogee GTZ on the EVGA X58 SLI?
  #22 (permalink)
Old May 21, 2009, 08:48 PM
Dazmode's Avatar
Same as on any other board, just do as as it says in instruction manual.
Orange Build: Final Video
HTPC Build: Final Video
  #23 (permalink)
Old May 27, 2009, 01:50 PM
I see all those add-ons, liquids... I dont know what liquid to use... I just leaked test my loop with tap water. Can I use tap water into a watercooling loop?
LC.
  #24 (permalink)
Old May 27, 2009, 02:22 PM
Dazmode's Avatar
Are you joking or serious?
  #25 (permalink)
Old May 27, 2009, 02:30 PM
Dazmode's Avatar
Wash your loop ASAP with distilled water (Shoppes has it for 2.99)
If you're trying to be cheap (nothing is wrong here), you need distilled water + addictive against algae for two reasons:
1) Non conductive
2) Doesn't crap your blocks and tube with minerals...
3) No seaweeds
Specialized liquids, like Feser One also have anti-corrosive component, anti-algae component, performance improving additives and finally UV reactive component.
  #26 (permalink)
Old May 27, 2009, 08:55 PM
Is this all right? For biocide + coolant?
NCIX.com - Buy Feser One Fluid UV Blue NON-CONDUCTIVE Water Replacement for Liquid Cooling - 4 260119 640016 In Canada.
  #27 (permalink)
Old May 27, 2009, 09:22 PM
Dazmode's Avatar
No biocide for Feser, it has it already. Any other chemical may get you into unwanted chemical reaction...prohibited.
  #28 (permalink)
Old May 27, 2009, 09:30 PM
Is it a big deal that I used tap water for leak testing? Such a noob I run first thing tomorrow at my grocery to get some distilled water. What kind of biocide is available in here?
  #29 (permalink)
Old May 27, 2009, 10:00 PM
MpG's Avatar
MpG MpG is offline
Nothing's going to explode, but regular tap water has a wide variety of minerals in it, which over the long term, can lead to buildup of deposits (not unlike the lime in that builds up in your kettle) that can degrade your system's performance. So a few flushes of distilled water could be beneficial long term. As a possible side benefit, distilled water is actually fairly unconductive at first, so an early mistake might - MIGHT - not wreck things. Of course, that's a poor attitude to take, when there shouldn't be leaks in the first place.
  #30 (permalink)
Old May 28, 2009, 05:53 AM
Dazmode's Avatar
Agree with MpG. Not a huge deal, for a day or two not much can build up on your block's cooling fins.
[WTB] Looking for all WC gear. First loop. Eatstone Buy/Sell & Trade 9 December 19, 2008 01:11 PM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
Best Way of Draining my Loop? Phobia Water Cooling 4 June 9, 2008 05:39 PM
Advice on loop needed ... Synth Water Cooling 8 May 9, 2008 05:31 AM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
