<~----> Advice/comment on my watercooling loop - Page 2 - Hardware Canucks
Old May 11, 2009, 09:38 PM
JD JD is offline
Originally Posted by LC0g View Post
All right the killer question... What are the best fans for this radiator???
Thanks!
LC.
Yate Loons (from Petra), Zalman ZM-F3, Scythe S-FLEX series. That's going by Vapor's reviews (Admin on XS)
Old May 12, 2009, 06:35 AM
Here is what I have for now:
Swiftech MCR220-QP
Swiftech Apogee GTZ + Swiftech LGA1366 Hold Down adapter plate
Swiftech MCP655
Swiftech 7/16'' ID Clear Vinyl Tubing
Bitspower High-flow G1/4, 1/2''ID dark plated nickel barbs
Scythe S-Flex 1600rpm, 63.7CFM at 28DBA
I think it's great :P... I think I'll add a t-Line to get a fill port. No reservoir...
Old May 12, 2009, 07:11 AM
Dazmode's Avatar
Looks good. I'd add fillport/stop fitting although.
Orange Build: Final Video
HTPC Build: Final Video
Old May 12, 2009, 08:50 AM
ChuckleBrother's Avatar
Great selection of parts, I am using those same fans, and Sidewinders is sending me another 5 to outfit the rest of my rig. You will be really really happy with them, sub ~1200RPM and you have what I would call sleepable silence levels(I sleep only 10 feet from my pc).
I really have to recommend a reservoir though, t-lines WORK but you just can't beat the bleeding/draining abilities of a well located reservoir. I've done both and I really have to say that a proper reservoir spanks a t-line, any day.
"...you play a mean banjo"
Old May 12, 2009, 09:19 AM
Yeah I was looking at the Ek Water multioption reservoir 150 rev2. Seems to be a great reservoir. It's gonna be cramped all over though with an antec 1200
Will be tight.
Old May 12, 2009, 09:40 AM
It is, I also have one of those:). It's really quite small though, I imagine you should be able to fit it(should).
Some pics of your case and what's in there would be helpful.
Old May 12, 2009, 06:02 PM
Sagath's Avatar
Originally Posted by Dazmode View Post
I'm still working on this. All I can say it is not GELID.
*shrug* I got a 5c drop on my parts, both GPU and CPU, with GELID's. And they are much more quiet then the Scythe's I did have before.
Originally Posted by Lpfan4ever View Post
AKG shot the hamsters, and then Perineum drove his Mustang with summer tires into the server.
Old May 12, 2009, 06:27 PM
element291's Avatar
The 220 is a great choice for the 1200. It fits perfectly in the front of my 1200 with 4 scythes on it.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
  #19 (permalink)
Old May 12, 2009, 06:58 PM
Dazmode's Avatar
Is it on radiator or on the case? Push or pull?
  #20 (permalink)
Old May 16, 2009, 01:12 PM
Can you guys tell me if I will see higher temperature when mounting the 2x120mm radiator on top of the antec 1200, just under the big boy fan?
[WTB] Looking for all WC gear. First loop. Eatstone Buy/Sell & Trade 9 December 19, 2008 12:11 PM
WaterKegIII Extreme external Watercooling unit, Watercooling stuff Apollo4g Buy/Sell & Trade 9 June 9, 2008 09:49 PM
Best Way of Draining my Loop? Phobia Water Cooling 4 June 9, 2008 05:39 PM
Advice on loop needed ... Synth Water Cooling 8 May 9, 2008 05:31 AM
My Soon-To-Be loop Kopi Water Cooling 5 October 23, 2007 12:49 PM
