Old May 10, 2009, 09:21 PM
Default $300 LCS
I was wondering if someone on here could put together(parts list) a water cooling system for my AMD phenom ll x4 955 processor
I'm a water cooling noob so preferably something fairly easy to setup and at a maximum price of $300
(preferably red colour, tubing or coolant; whats better?)
thanks for any help
Old May 10, 2009, 09:53 PM
Get the parts listed here, minus the additive, IMHO.
NCIX.com - Buy Swiftech H20-220 Apex Ultima Universal CPU Liquid Cooling Kit - H20-220 APEX ULTIMA In Canada.
Old May 10, 2009, 10:24 PM
Cptn Vortex's Avatar
That should do
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old May 10, 2009, 10:27 PM
Yep, that works. I'd srping the extra for the MCP655 myself, you know why by your sig ;).
Old May 10, 2009, 10:54 PM
Originally Posted by Cptn Vortex View Post
That should do
how would I mount this on a antec 1200
Old May 10, 2009, 11:09 PM
Phobia's Avatar
There are a couple of ways to do it without having to cut your case. You could buy This or remove your harddrive bays in front and attach it to the front
Old May 11, 2009, 06:02 AM
Yeah you would do this to mount it. Personally I'd rather have it out back, that way your video card is still getting fresh air.
Old May 11, 2009, 06:06 AM
matsta31's Avatar
And you can go sans Reservoir. where aere you located ? I got an MCR220 I dont use, you could save even more !
Sold hardware again.....
Currently using WHS hardware....
Old May 11, 2009, 07:55 AM
JD JD is offline
Why not mount the radiator directly to the dual 120mm rear fans? I think there's enough space to do so...
Old May 11, 2009, 10:51 AM
I have not personally built a machine in the 1200, but there should be more than enough room for a bunch of different configs. Front, back, rear, maybe even top!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
Watercooling:
His radeon HD4870 $250.00 Cranky Buy/Sell & Trade 20 March 10, 2009 04:34 PM
Best gaming card for 250$ vikrant.forums Video Cards 15 October 10, 2008 12:16 PM
Best AMD processor for 250$ vikrant.forums CPU's and Motherboards 7 October 5, 2008 08:46 PM
