Old May 7, 2009, 09:26 AM
nckid4u's Avatar
Default 2X120mm rad dual gpu+cpu loop
I know Charlie is running 2 gpus and a cpu in a loop with a 2x120mm rad. Is there anybody else with input on this idea. I have 2 MCW60s and an older DD cpu block, a MCP655 Vario and an unidentified 2x120mm radiator I bought from some guy I am Pretty sure it is a dual pass rad though.) I am planning on running this along with a DD Dual Bay Res to cool my rig. It will be a q6600, 2 gts250s with the rad mounted internally at the top of my cm590. I fold on the cards (don't really oc them - nudge the shaders a little) and the cpu will likely run at around 3.2GHz at low vcore. Some tell me not to run gpus and cpus in the same loop, but I am not looking for the record temps or anything like that. I just want to be able to fold on this 24/7 (gpus only) without keeping the entire house awake from the roaring fans.
Thoughts??
Thanks in advance.
When all men think alike, nobody thinks very much.
Walter Lippman
2600K @ 4.8GHz 1.44v
ASRock Extreme4
GTX 460 SLI
Old May 7, 2009, 10:01 AM
MpG's Avatar
MpG MpG is offline
If you want to post a picture of the rad, someone could probably identify it, which would ensure that you're not trying to use a serious piece of crap or something. Also, what's your idea of a quiet fan?
You shouldn't have any trouble running that sort of setup. Your temps will definitely be higher than normal, and honestly, you could probably get just as good temps with good aircooling, but it will work. Just make sure you properly clamp all barbs (the warmer water might manage to make the tubing slightly softer).
Old May 7, 2009, 10:37 AM
nckid4u's Avatar
The rad is in this picture.
Walter Lippman
ASRock Extreme4
GTX 460 SLI
Old May 7, 2009, 10:41 AM
Supergrover's Avatar
Looks like a pa120.2 to me
Old May 7, 2009, 10:52 AM
nckid4u's Avatar
I sure hope so. They are a great rad AFAIK.
Walter Lippman
ASRock Extreme4
GTX 460 SLI
Old May 7, 2009, 11:41 AM
matsta31's Avatar
could you give us a estimate of the tickness ?
Sold hardware again.....
Currently using WHS hardware....
Old May 7, 2009, 12:42 PM
MpG's Avatar
MpG MpG is offline
Can't quite place the rad. It's either a a PA120.2 (but the fan holes look too close together) or an XSPC RX-series radiator, although those are pretty new (and there should be a stamping somewhere to identify it). Either would be excellent.
Old May 7, 2009, 12:57 PM
ChuckleBrother's Avatar
I really don't think that's a thermochill, it doesn't look thick enough nor do the fan spacings look correct. My bet would be a Black Ice or maybe a Magicool rad.
"...you play a mean banjo"
Old May 7, 2009, 01:02 PM
Better Image showing the side profile would make it easier.
Old May 7, 2009, 01:04 PM
Definitely not a thermochill.. not of anything recent.
[WTB] Looking for Dell S2309W and 2x120mm Rad Akai Buy/Sell & Trade 3 April 5, 2009 03:17 PM
micro PC Gaming for sale 1gb SLI GPU Dual core CPU Black - $650 luirhino Buy/Sell & Trade 6 September 12, 2008 06:00 PM
TJ-07 dual loop help.... turtletrax Water Cooling 17 August 13, 2008 04:56 PM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
