-   -   Intel 775 Heat Sink - QUICK question (http://www.hardwarecanucks.com/forum/water-cooling/1751-intel-775-heat-sink-quick-question.html)
mattydies June 26, 2007 01:12 PM
There are 4 holes to mount my cpu heatsink to my MoBo.
MY Question is this - DO the holes form a perfect Square? Or are they rectangular?
Thanks in advance for the help.
I need to find out so that I may decide my fan layout within my case.
Misoprostol June 26, 2007 01:46 PM
they are a perfect square on LGA775.
Moneyless June 26, 2007 02:04 PM
Yeah you can tell they are a square by actually looking at them...
mattydies June 26, 2007 06:57 PM
Thanks guys :thumb:
I figured some one would know. I did not feel like pulling it off to measure if I did not have to.
Since they are Square I can
PROPERLY set up my case for good air flow :biggrin:
Thanks again, this place is great :canadianwave:
