-   -   i got a LEAK! (http://www.hardwarecanucks.com/forum/water-cooling/17438-i-got-leak.html)
kyle_L April 30, 2009 02:04 PM
i got a LEAK!
i went and installed a new dvd drive last night and i found purple fluid allover the bottom of my case. i was stumped to were the fluid was coming from casue all the barbs were tight and the place it was leaking from should be casue it was installed when the computer was built. after draining my system and taking out the bitspower t that was installed i noticed it was cracked from one hole to the other, what i would like to who is how the :censored: could this happen. im just glad it was a slow leak and not a gaping hole. i wonder if i can get sent a replacement. i will post a pic later.
MpG April 30, 2009 02:13 PM
Bitspower T? Acrylic? They're known to crack from over-tightening the barbs.
kyle_L April 30, 2009 02:19 PM
ya its acrylic. and it wasn't overtightened. i was very care full not to over tighten it, cause i didn't want this to happen. i was using there barbs on it too.
gingerbee April 30, 2009 03:43 PM
acrylic and dry heat in the case might have caused it to crack but it would be a first for me. just a guess
KaptCrunch April 30, 2009 05:03 PM
1 Attachment(s)
heat cycles kill plastics lost one SLI card to a hairline crack
CanadaRox April 30, 2009 08:36 PM
I would definitely contact Bitspower about getting a replacement. I've read on XS that they have good customer service so I'd expect they would do an RMA without an issue.
zlojack May 1, 2009 04:56 AM
Yeah, those acrylic Ts are a PITA and very delicate.
Get yourself one of these babies! Bitspower Silver Shining T-Block - # BP-TMB
sswilson May 1, 2009 05:03 AM
Acrylic anything in a loop can be a pain. I learned from my first loop (TT Bigwater) that I didn't want any acrylic after going through two different acrylic top CPU heatsinks (lost a 1950pro to that).
It doesn't take much to overtorque the threads, and any hairline cracks which form are hard to see and can take months to get bad enough to start leaking.
zlojack May 1, 2009 05:06 AM
I had a custom reservoir made for me by CyberDruid and it cracked around the barbs because of overtightening. I wrecked my whole design of my H2GO water setup :sad:
Anyway, the only acrylic in my new build will be the XSPC Res tops for my pumps.
gingerbee May 1, 2009 05:10 AM
had same problem with tt stuff
