Old June 25, 2007, 01:00 PM
mattydies's Avatar
Default Modifying my CPU Heat Sink???
I have an "Arctic Cooling Freezer 7 Pro" as my CPU cooler.
Arctic Cooling Freezer 7 Pro LGA775 2500RPM 45CFM - DirectCanada
I received the item it appeared to be nicely made, however I did notice slight lines on the bottom of the copper base - surely from the machining / manufacturing process.
The lines are small enough to be acceptable, BUT I could sand them off (perfectly flat surface and sand paper start at 320 then get finer and finer - I have tonnes around as I am a huge car enthusiast).
Could this provide better contact for thermal conductance? (IE Lower CPU Temps)
I am FAR from having issues with heat, but if it would be a slight improvement I will gladly do so.
The price is right
Old June 25, 2007, 01:10 PM
BALISTX's Avatar
There is a process known as lapping that will reduce the temps of your CPU. Here is an article that shows you how to lap your heatsink.
Overclockers Club - How to Lap a Heatsink Guide
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old June 25, 2007, 01:12 PM
Moneyless's Avatar
QFT.
That's basically what I was going to say but he's saying it better.
Also you don't need to start with 320grit, you can start with 800, then go 1200, then 1400, then 2000, and use the micron grits if you have any for shininess (although the shine doesn't change the thermal efficiency, it's purely for bragging rights.)
"I hate broccoli
And think it totally sucks
Why is it not meat?"
-Deadpool
Old June 25, 2007, 01:13 PM
Patriote's Avatar
I heard that lapping WB wasn't a good thing. But never heard anything about lapping an heatsink. Should be a good thing. I think...
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old June 25, 2007, 01:45 PM
Supergrover's Avatar
Yeah Lapping will help a bit very minor though still it all adds up.
R.I.P.
Old June 25, 2007, 04:05 PM
mattydies's Avatar
I will be lapping my CPU Heat Sink one of these days when I have some excess time.
Thanks for the URL and everyones help
Old June 25, 2007, 05:55 PM
Moneyless's Avatar
How would lapping a waterblock be bad? All lapping does is make the base smoother and flatter to allow more contact with the CPU (or other thing, ie SB, NB, w\e.). The only waterblocks I know of which arn't supposed to be lapped are Stinger waterblocks, because they are perfectly pre-lapped and the copper base is so thin that lapping it any more would expose the inside of the waterblock's channels.
"I hate broccoli
-Deadpool
Old June 25, 2007, 08:22 PM
Patriote's Avatar
Go tell this to XS members...lol
• - Noctua NH-D14
Old June 25, 2007, 09:03 PM
Moneyless's Avatar
Well I'm not a member of XS so HAH!
lol.
"I hate broccoli
-Deadpool
Heat Issue Lyxtwing Video Cards 8 March 14, 2008 08:35 AM
what is a decent air heat sink Shadowmeph Air Cooling 13 January 8, 2008 05:46 PM
modifying side panel silverchair Cases 15 August 16, 2007 11:19 AM
Intel 775 Heat Sink - QUICK question mattydies Water Cooling 3 June 26, 2007 06:57 PM
Heat sink and fan selection for Intel Pentium D 915... mattydies CPU's and Motherboards 6 March 17, 2007 09:36 PM
