Old April 25, 2009, 10:14 PM
SugarJ's Avatar
Default Pump rattle?
So my CPX-Pro has developed a rattling noise, as of a couple of days ago. It sits on a block of Petra's Gel-stuff, so its not the case. I tore the loop down today, cleaned my block and res, flushed my rad, and took the pump inlet off, didn't see anything built up on the impeller.
Any suggestions? Because I started to WC because of noise, and this is driving me slightly nuts.
Old April 26, 2009, 03:56 AM
gingerbee's Avatar
new pump because anytime my pumps start to make noise is when there about to die
Old April 26, 2009, 04:02 AM
KaptCrunch's Avatar
bearing or cavitition makes noise
what happeneds if shut off flow by squeezing/kink the outlet tube ?
sound gone ? if so then you got cavitition problem
still noisey ? replace pump
Old April 26, 2009, 09:05 AM
SugarJ's Avatar
Must be a bearing going bad. Sigh. This pump is only 7 months old.
Old April 26, 2009, 09:17 AM
LionRed's Avatar
What does the pumping in these pumps? Are they Magnetic Drive Impeller? Could he just replace the the impeller?
Be interesting to see a picture of the insides of one of these pumps...if anyone could post one.
Choo Choo bitches, progress coming through.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy
Old April 26, 2009, 09:18 AM
SugarJ's Avatar
Yes it is a magnetic drive impeller. If I decide to take it apart again I'll post some pics.
EDIT: I think I just figured out what the white floaties were in my loop. I think the impeller is slopping around, and hitting the outlet, and shaving off the ends. That's the ticking noise I'm hearing.
So a new pump is probably in order.
Old April 26, 2009, 10:02 AM
gingerbee's Avatar
sorry 7 months that did not last long
[WTB] Water pump HiTi Buy/Sell & Trade 4 February 23, 2009 11:25 AM
WTB pump Eldonko Buy/Sell & Trade 0 June 30, 2008 12:12 PM
Pump design. BrainEater Off Topic 3 June 20, 2008 05:47 AM
pump not turning on? stormkiller22 Troubleshooting 8 April 4, 2008 01:17 AM
Pump Question lcdguy Water Cooling 10 February 19, 2008 07:58 PM
