Old April 23, 2009, 03:36 PM
Default The Feser Fairy
Had a lil visit from the Feser fairy today...
Too bad one of the rad's has 17mm spacing
Old April 23, 2009, 03:59 PM
Liu Kang's Avatar
Sweet set of rads there, Franky... but I don't get how one is 17mm fan spacing and the others aren't? I thought all Fesers were 15mm?
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old April 23, 2009, 04:15 PM
MpG's Avatar
MpG MpG is offline
Damn, they've still got 17mm models circulating? Thought those were long gone by this point. You going to fit all those in one case?
@Liu Kang: Originally, the double and triple models were 17mm spacing, but shortly after, they switched to 15mm to standardize them to what most other rads were using, as well as many cases that are designed to hold rads without mods.
Old April 23, 2009, 04:33 PM
Yeah they were all supposed to be 15mm but i guess they managed to sneak an old one in, it will be heading back soon. As for the case i haven't decided yet, its in between mm ufo cyo extended or a lian-li pc 343-b.
Old April 23, 2009, 04:55 PM
MpG's Avatar
MpG MpG is offline
Which rad is the 17mm version? The double? Standard spacing on the MM back panels is a god-forsaken 17mm, which ticked me off when I wanted to throw a ST double on the back. Was actually considering about finding a Feser double at the time, but finally just settled for installing screws at an angle.
Old April 23, 2009, 05:03 PM
Only because MM cases were originally designed for PA series radiators :P
And now the PAs will be changed too hahaha.
Old April 23, 2009, 05:17 PM
Dazmode's Avatar
Good choice, TFC is the best!
Orange Build: Final Video
HTPC Build: Final Video
Old April 23, 2009, 05:19 PM
MpG's Avatar
MpG MpG is offline
It's worse, actually. The TC's are ~25mm spacing. I believe some old Swiftech's may have used 19mm spacing. Nothing uses a 17mm spacing. Except for the first run of Feser rads. I can't for the life of me figure out why they used that spacing on the back panel. 2mm less, and 90% of all double-rads would have been a no-brainer fit.
MM tools.
Old April 23, 2009, 05:23 PM
One of the triples had the 17mm spacing, also according to the serials they were only 2 numbers apart?
Old April 23, 2009, 05:32 PM
Dazmode's Avatar
What is the serial #?
What you guys think about new Feser fans? Dazmode Water Cooling 37 June 26, 2009 12:56 PM
Feser Xchanger Triple... where to buy? vinister Water Cooling 29 March 9, 2009 10:54 PM
[WTB] Thermochill PA.120.2/3 Or Feser 240 radiator... Apollo4g Buy/Sell & Trade 0 February 18, 2009 10:06 PM
WTB Feser One Blue UV PLEASE!! @_@ EDMCR Buy/Sell & Trade 2 July 30, 2008 05:25 PM
