  #31 (permalink)
Old April 22, 2009, 08:11 AM
ChuckleBrother's Avatar
Originally Posted by Dazmode View Post
+1 for this post, although for high-restrictive blocks like Koolance 350 dual loop is valid option too.
Yup, or an EK Supreme, those things are also pretty bad for being restrictive. When it comes to rads, I am of the belief that you should buy as big as your budget allows for(and your case can fit), since if you ever find yourself upgrading to hotter/more components it will always cost more to add more rad space after the fact.
"...you play a mean banjo"
  #32 (permalink)
Old April 22, 2009, 08:12 AM
Dazmode's Avatar
Originally Posted by dataxpert View Post
Itís what I thought too before, but Biff make me realize than the CPU will be at same temps than the GPU.
I think it is incorrect as CPU get water from the rad and GPU from CPU...
Orange Build: Final Video
HTPC Build: Final Video
  #33 (permalink)
Old April 22, 2009, 08:22 AM
biff's Avatar
Good advice. That big killer rad maybe over kill now but it saves you having to redo your entire loop when you upgrade. I've been using my same dual chevette heater cores for 5 or 6 years now.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Silent Hill Homecoming cmac79 Gaming 2 November 15, 2008 07:28 AM
Silent PSU Phobia Power Supplies 6 October 15, 2008 12:40 AM
Silent Power lcdguy Case Mods, Worklog & Gallery 13 February 27, 2008 06:56 PM
The Silent Monster Dark Case Mods, Worklog & Gallery 3 January 9, 2008 01:40 PM
Silent PSU? cdn_Madrach Power Supplies 2 June 11, 2007 06:01 AM
