Old April 22, 2009, 09:09 AM
magictorch's Avatar
I'll look into that but Im kind of leaning towards the clean tube look.
Originally Posted by sswilson View Post
How about some standard white heatshrink from Princess Auto???? :)
You guys have come up with some great suggestions! I'll take a look at the silver/grey, sometimes its not about having the best components- its how you present them that counts
Old April 22, 2009, 12:55 PM
CanadaRox's Avatar
You could always get Tygon B-44-4X (tubing designed for dairy) and fill it with milk! You'd probably have quite a problem with growth in the fluid though...
Project: Black and White
Old April 22, 2009, 01:20 PM
S_G's Avatar
S_G S_G is offline
Originally Posted by Dazmode View Post
I still waiting for my tubes to arrive... Is silver looks silver or more like a dark grey?
It's a dark silver. I wouldn't call it dark grey, since the tube has a sort of bluish, metallic tinge to it. I think dark grey implies a more matte style as well. It looks good though, I can tell you that much.
It's all old! Workstation: X7DWA-N : 2x Xeon E5330 Quads @ 3GHz + 24GB FB-DIMM DDR2-800 on water (Goodbye, Skulltrail.)
Rocketfish LL case painted black // PCP&C Silencer 750W
1x 8800 Ultra --> Sony GDM-FW900 + LVM-37w3se // HT Omega Striker ~ (optical) Pioneer SE-DIR800C ~+ SE-DHP800 / HD 280 Pro (HD380Pro soon)
HTPC: E1200@3.2 + IP35 + 4GB DDR2-800 + HD4850 + Silverstone Kublai KL02
Router (WIP): Intel Atom 230 + Intel PRO/1000 GT + GS108T gigE switch + WRT54GL + a drawer
It's very shiny. You might need sunglasses. crispex New Builds 89 March 19, 2009 06:40 PM
Build for my shiny new i7 920 Veeediot New Builds 3 December 29, 2008 05:27 PM
Cutting tubing elninio Water Cooling 11 June 10, 2008 04:14 PM
Fans for WC and tubing Dashock Water Cooling 7 May 5, 2008 10:13 AM
Tygon tubing Dark Water Cooling 5 December 28, 2007 07:42 AM
