Old April 12, 2009, 11:39 AM
Default Compression Fittings
hello again.
I want to use compression fittings for my wc.Can i use compression fittings for this parts:
Swiftech MCR220 and MCR120
XSPC Laing DDC Reservoir Top
XSPC X2O Delta CPU Block V3
Swiftech MCW60-R2 GPU
www.miculhomereno.com
Old April 12, 2009, 11:54 AM
Swiftech MCR220 and MCR120 yes
XSPC Laing DDC Reservoir Top yes
XSPC X2O Delta CPU Block V3 dont know
Swiftech MCW60-R2 GPU no
Old April 12, 2009, 02:02 PM
ChuckleBrother's Avatar
I seem to remember though that you may be able to for the MCW60 if you use some extenders. Might be wrong on that.
For the XSPC block: likely. From the pictures it looks like the inlet/outlet are fairly far apart. It's still going to depend on what size of compressions of course, and a 45 degree fitting on one of the fittings will likely let you use them no matter what.
"...you play a mean banjo"
Old April 12, 2009, 05:52 PM
MpG's Avatar
MpG MpG is offline
MCR120/220 - yes, but be careful, since the holes for the fittings are countersunk, and the stock orings on the comp fittings may not be thick enough to seal 100%. This problem comes up with the GTZ water block as well. For best assurances, hit up your local auto/plumbing store and get some thicker o-rings to use.
XSPC Restop - no guarantees on the comp fitting working on the outlet. It's angled upwards slightly, and the top edge of the fitting's base may be blocked by the walls of the reservoir. Stupid design, imo.
Old April 16, 2009, 03:09 PM
i just saw this stuff Bitspower G1/4" Black Sparkle IG1/4" Extender Products Model: BP-BSWP-C40 [BP-BSWP-C40] : Performance-PCs.com, ... sleeve it and they will come
i think i can use them?
Old April 18, 2009, 03:21 AM
MpG's Avatar
MpG MpG is offline
Yeah, those should work fine for the restop and rad. Won't do anything for the situations where the holes are too close together, of course.
[WTB] BP 3/8" ID 1/2" OD compression fittings netforce Buy/Sell & Trade 0 April 2, 2009 07:42 PM
Fittings Issue JD Water Cooling 6 February 15, 2009 07:15 AM
Bitspower G1/4 Straight Compression Fittings BALISTX Water Cooling 8 October 12, 2008 10:19 AM
Bitspower Fittings JD Water Cooling 10 August 14, 2008 10:29 PM
compression fittings in Canada? lowfat Water Cooling 2 April 30, 2008 12:37 PM
