Old April 5, 2009, 12:15 PM
Originally Posted by cadaveca View Post
the swiftech 4870 block will work for you...I have 2 of the same cards, and am travelling dow nte smae path as you...these cards NEED water. No such thing as a decent air cooler, that doesn't take up three slots, which is no good with me having more than one card.
Did you mean this block? In the chart at the bottom of the page it specifically says my card is not compatible with the mosfet cooling, but is compatible with the ram and gpu core. How much of a load is from the mosfets? Would a small heatsinks be fine on the mosfets?
The only reason I would cool my cpu is to make more room in the case for a rad behind the cpu socket.
As far as a single 120.1 rad, I'm not going for record overclocking so if my temps under load hit 50-60C I could handle it. What sort of load temps could I expect in worst case scenario?
Old April 5, 2009, 12:35 PM
there is already a heatsink on the mosfets, so simply remove the mosfet attachment on the block, and put some quiet 40mm fans over the 'fets. I might even see if I cannot intergrate the heatpipe into the stock mosfet heatsink...
Take a look at the Sapphire Toxic 4870x2...two of the same cores on a single 120mm rad, plus cpu block. With aircooling the vga's power area, as well as no cpu, it should be ok, but if possible, I'd suggest a 2x120mm rad for when summer hits.
Old April 7, 2009, 04:13 PM
I'm thinking I may just go with the Thermalright Trad, as it should fit my application and run cooler and quiet.
[FS] Diamond 4870, XSPC Razor 4870 Block SugarJ Buy/Sell & Trade 4 March 26, 2009 02:26 PM
Video upgrade - 4870 1GB vs 4870 X2 Maplicito New Builds 10 February 24, 2009 12:40 PM
[WTB] 4870 X2 SynCroNiz3 Buy/Sell & Trade 0 February 15, 2009 11:50 PM
[WTT] Visiontek 4870+Cash for your 4870 X2 Apollo4g Buy/Sell & Trade 2 February 6, 2009 08:00 PM
1 gig 4870??? WolfBane Video Cards 8 July 19, 2008 08:27 PM
