Originally Posted by MpG They're not as bad as many people make them out to be, especially if you have a strong pump. But if you've got that many elbows, I think you really need to look at your system and ask yourself if there's a better way of doing things. |
Agreed.
Every WC build has a bottleneck somewhere, meaning that something within the loop(s) is the least efficient component. I always say that a loop is only as good as it's weakest component...
That being said, unless your loop has excessive tubing and 90 degree bends, chances are your bottleneck would be a weak pump, a restrictive block/rad, inefficient rads, etc.
Like MPG said, if you need that many 90s you might need to take a closer look at your WC layout and make changes accordingly. Then again, I am building an mATX WC rig, so who am I to talk... :)
