Old April 1, 2009, 07:46 AM
Barber's Avatar
I'm going to load it up with OCCT in like 45 minutes before I head to class, I'll post results later. There is for sure something wrong with all these monitor softwares, as they all say my proc is at 2ghz not 3ghz... It's got the multi 3 lower then what it's actually at... So weird... Anyway I'll get results later!
Albi The Racist Dragon:
http://www.youtube.com/watch?v=g9Qu3iP3RYA
Old April 1, 2009, 09:09 AM
biff's Avatar
That multi thing is probably speedstep kicking in, 6x multi when idle 9x when loaded, you can disable it in BIOS.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old April 2, 2009, 09:19 AM
Barber's Avatar
So this is what my OCCT test after an hour.
No to sure what to make of these results. Seems to indicate something quite a bit different then what both Core Temp and Real Temp read. Both got up to 50, but did not break the 50 degree mark.... What's going on here? Bad TIM application or just bad monitoring software??
[Edit] As to the above post, you are right for sure, forgot I still had that on. Thanks a ton!!
Old April 2, 2009, 09:27 AM
gingerbee's Avatar
stuck sensor is what it sounds like to me
Old April 2, 2009, 10:02 AM
Barber's Avatar
Hey, Thanks to everyone helping me out on this. I really appreciate it!!
How does one fix that issue?? I really don't like the idea, of not accurately(or even vaguely) knowing my CPU temps.... Which temps seem more plausible? The OCCT graph shows kind of more along what I expected, with room temp around 19, the processor starts around 21 and peaks around 30 under load. Does this make more sense then the real temps and core temps which begin at around 40 and peak at around 50? I don't want to start oc'ing and testing the IC7 without first accurate readings on what my temps with the MX-2 are...
Again thanks everyone for the help!
Old April 2, 2009, 12:36 PM
MpG's Avatar
MpG MpG is offline
Unfortunately, I don't know that I'd trust OCCT for temps right now. Right now, even the latest version is trying to tell me that one of my processor cores is at 8 degrees, which obviously isn't possible.
Use Realtemp, and make sure the target/TjMax value at the top is 100 degrees, which I believe is standard for all E8-series processors. Beyond that, the lower the value, the worse the accuracy of the chip sensors will be - by design, they're optimized to detect max temps around 100-ish, and no bets on anything else. Despite the inaccuracy, you should at least be able to make an apples-to apples comparison, as long as you use the same monitoring program for each chip.
Old April 3, 2009, 08:06 AM
Barber's Avatar
So considering this is probably bad monitoring software, how should I go about testing the IC7 I just got in the mail??
Thanks guys!!!
Old April 3, 2009, 04:05 PM
3.0charlie's Avatar
Use the same apps - what you're looking for is a delta between the TIM you are using, and the IC7.
Hydro-Quebec is salivating...
  #19 (permalink)
Old April 6, 2009, 10:02 AM
Barber's Avatar
So even if he temps are wrong, the delta between them should still be accurate. Sounds logical enough. Thanks for the help!
E8400 - Core Temps Lower than CPU Temp Capt Proton Water Cooling 0 January 25, 2009 03:32 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
E8400 temps miggs78 CPU's and Motherboards 14 September 8, 2008 05:36 PM
E8400 Core temps - OCZ Vendetta 2 cooling Dwayne Air Cooling 8 August 17, 2008 01:13 PM
E8400 Idle Temps... rjbarker Overclocking, Tweaking and Benchmarking 13 April 14, 2008 02:36 PM
