<~----> question for wc guru's - Hardware Canucks
Old March 31, 2009, 01:39 PM
gingerbee's Avatar
Default question for wc guru's
i have not used any bitspower fitting before and would like to know if anybody has used there fittings (1/2') with swiftech rads before ( about to order and want to make sure the fittings i like will work i think they will but would like to hear from the horses mouth
Old March 31, 2009, 01:46 PM
JD JD is offline
I have BP fittings on my Swiftech MCR220. Works fine. They are just G1/4 threads and thus the G1/4 barbs work fine.
Though if you have a really old Swiftech rad, then it's probably not G1/4, so you'd probably need an adapter or something.
Old March 31, 2009, 01:48 PM
gingerbee's Avatar
no just bought new swiftech tripple rad thanks for a quick answer
Old March 31, 2009, 01:50 PM
SugarJ's Avatar
+1 to the BP's, they are my favorite barb hands down.
Old March 31, 2009, 02:09 PM
MpG's Avatar
MpG MpG is offline
The regular fatboys fit just fine. The compression ones are a little iffy, since they're wider than the recessed inlet. Best to find a thicker o-ring if you want to use those.
Old March 31, 2009, 05:03 PM
Liu Kang's Avatar
Thermochill PAs and old Swiftechs are the only G3/8 threaded rads I know of...
Bitspower also makes a G3/8 to G1/4 conversion fitting -- another reason they are the best on the market.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old March 31, 2009, 06:10 PM
it also make g3/8
Old March 31, 2009, 06:16 PM
Liu Kang's Avatar
Originally Posted by phil3_66666 View Post
it also make g3/8
True, but I think they are only available as barbs. All the nice, fancy stuff (compression fittings, rotaries, etc.) are all G1/4 .
LK
Old March 31, 2009, 06:39 PM
JD JD is offline
Here's my setup:
BP 90 degree dual-rotaries w/ Koolance QD VL3
Old March 31, 2009, 06:40 PM
JD JD is offline
Here's my setup:
BP 90 degree dual-rotaries w/ Koolance QD VL3. No leaks to speak of. Never had any issues with BP fittings. Always leak free.
question for you rosetta guru's Phobia HardwareCanucks F@H Team 12 February 21, 2009 07:30 AM
