Old March 31, 2009, 06:46 PM
Liu Kang's Avatar
Nice, jdrom... that's about $30 of fittings right there.
Ugh.
My bitspower order is going to push $200 by the time it gets delivered, worth every penny though -- they'll last for countless builds.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old March 31, 2009, 06:52 PM
Supergrover's Avatar
Ugh.
Yup they get pricey fast, once you start adding adapters, T's, Q's, ect.
Those quick disconnects are going on my rad next loop, Those are badass JD
Old March 31, 2009, 07:44 PM
MpG's Avatar
MpG MpG is offline
Take a look at Koolance's VL4 series of QD's. Definitely more open and less restrictive than the VL3's. Bloody massive, though.
Yes, that's a 1/2" fatboy fitting next to it.
Old March 31, 2009, 07:52 PM
gingerbee's Avatar
i ended up buying the danger den and bp fitting to try the bp's out thank for all the pics helps alot
question for you rosetta guru's Phobia HardwareCanucks F@H Team 12 February 21, 2009 07:30 AM
