Old March 30, 2009, 05:49 PM
Default WC question
Hi, again me for another water cooling project
My question are about pump,
first that what i want to watercool
Cpu-apogee gt maybe another one...
gpu-4870 full cover or maybe a normal swiftech block
pa 120.2 or swiftech 120.2
**maybe add swiftech 120.1
so the question, wil an mcp350 with an res top will be good? if yes what top i need? xspc?
also 3/8 tubing or 1/2?
Thanks
Phil
Old March 30, 2009, 05:56 PM
3.0charlie's Avatar
The MCP-350 (or 355) is more than enough, res-top or not. Here's my setup:
XSPC res
355
PA120.2
GTZ
Stock Extreme NB block
DD Tieton 1
DD Tieton 2
Hydro-Quebec is salivating...
Old March 30, 2009, 06:24 PM
Liu Kang's Avatar
The 350/355 will be more than enough, but I'd look at adding some rad to your setup... a 120.2 simply isn't enough for a cpu and gpu.
The xspc top is nice, there are other good ones out there too, but you can't go wrong with xspc.
The tubing doesn't make much difference. I always recommending going for 1/2 ID, but if you need to make some tight bends, or if you have small case, 3/8 ID will be fine.
Laisse moi savoir si tu veut que je traduit ;) Bonne chance!
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old March 30, 2009, 07:23 PM
Merci de vos réponse
et merci pour l'offre de traduction loll mais je lie mie en anglais(heureusement)
Old March 30, 2009, 07:28 PM
3.0charlie's Avatar
A PA120.2 can handle a whole lot more... mine's buried in there....
Old March 30, 2009, 07:33 PM
CMetaphor's Avatar
Quadfather
I'd trust 3.0charlie on this one... he knows more about WCing than most do about computers in general..
Old March 30, 2009, 07:44 PM
ChuckleBrother's Avatar
If you run the fans well enough on the swiftech you will be able to handle the output. Your delta might not be great but it will manage. Just don't expect to put your temps to extreme lows.
"...you play a mean banjo"
Old March 31, 2009, 10:14 AM
Liu Kang's Avatar
Judging by that picture, it looks like you are running a 120.2 (pull) to cool an i7, north bridge and 2 cards in SLI... am I mistaken? Please tell me I'm mistaken...
LK
Old March 31, 2009, 10:18 AM
3.0charlie's Avatar
No, you're not - except for the pull part: the fans are in push config (Scythe 38mms)
Old March 31, 2009, 10:33 AM
Liu Kang's Avatar
Kudos on the fans, I wish I had the space to run those bad boys... but that dual doesn't seem like it could handle the heat you're generating: the i7, 260s, NB... especially if you've OC'd them. Am I mistaken, again? ;) Care to share some temps/test results?
LK
