Old March 31, 2009, 10:52 AM
biff's Avatar
WC'ing is surprisingly effective at high heat loads. I think people get a little too bent out of shape over temps. Unless you're going flat out for max overclock there is nothing wrong with letting the temps run warm. Unless you get creative you pretty much have to decide if you want quiet with only one pump and a couple fans or loud and high performance running multiple pumps and lots of rads with push/pull screamers.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old March 31, 2009, 11:02 AM
lcdguy's Avatar
i would agree i once cooled.
CPU - X2 5000+
Video - 3850 in CF
with only a pa120.1 and it was more than enough. The thermochill rads are truly awesome.
Old March 31, 2009, 11:15 AM
Liu Kang's Avatar
En passant Phil, il y a une grosse différence entre le PA 120.2 et le Swiftech... la qualité et efficacité du PA est supérieur. Donc, si tu as le choix, le Thermochill est définitivement le meilleur des deux.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old March 31, 2009, 12:00 PM
Tout va dépendre du budget disponible mais merci pour le conseil
Old March 31, 2009, 01:26 PM
3.0charlie's Avatar
True, to an extent. The MCR-220 is very efficient with particular fans: the Yate Loons, the Scythe SFF21Fs amongst others. Could the 220 handle the load generated by my setup? No. The PA120.2? Absolutely.
920 oc'ed to 4.0 stock 260s, NB. While folding on CPU (dual SMP client), while folding on GPUs (dual GPU client):
68-70-64-66 on the i7
42 on GPU #1
43 on GPU #2.
Ambiant is 21C.
Rads are much more efficient that users tend to believe. Most have overkill rad setups.
Hydro-Quebec is salivating...
