Old March 29, 2009, 08:15 PM
crispex's Avatar
Default Pressure Relief Valve
Well, I am putting this in here because I find it funny, but there's also a question behind it.
First, a quote from Koolance:
The VLV-VL002K safety valve releases built-up air pressure in situations such as corrosion, thermal expansion, etc. (at approximately 0.3-0.4kg/cm2, 4.3-5.7psi) The pressure valve is designed to be screwed into the Koolance Fill Port, where it replaces the nozzle plug. This product should not be necessary for systems using only Koolance water cooling products.
Gotta love it, hey?
Anyway, the actual question: Has anyone here ever used something like that?
Secondarily, does anyone here think that a relief valve like that is necessary?
Koolance is also selling in-line filters, which are neat, but I assume would only come into play if you didn't flush your components properly.
Old March 29, 2009, 08:24 PM
Gotta love it, hey?
1) Filters will decrease flow; by how much hard to say and yes not needed unless you did a crappy job flushing your gear.
2) If you have a loop that requires a pressure relief valve your running more pump than you need.. you'd be blowing hoses off.
Old March 29, 2009, 08:44 PM
sswilson's Avatar
I've never noticed that one of my loops was "charged" with extra pressure. I'd think that there would have to be a lot of chemical reaction going on to require it, and if that's the case, overpressure would be the least of my worries. :)
Old March 29, 2009, 08:58 PM
Cptn Vortex's Avatar
Just open the top of the rest once a month or something. Thats all you should need...
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old March 29, 2009, 09:01 PM
Linus's Avatar
Or just don't put anything stupid in your loop.
A proper closed loop system shouldn't have any gas build up because nothing comes out that you didn't put into it unless you've got some kind of chemical reaction going on in there.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
Old March 29, 2009, 09:12 PM
Dazmode's Avatar
Here is pic. on how filter looks inside. Mesh is quite coarse, I don't think it will restrict flow too much, but it won't filter much either.
I'm also puzzled about that pressure valve thingy...
Old March 29, 2009, 10:09 PM
3 of 7's Avatar
Interesting.
Depending on the temps created, a relief valve could well be necessary if there isn't sufficient airspace in the system, as you know air will compress but liquid, not so much.
The problem with a one way relief valve is, if your creating that much pressure by heating the water, it stands to reason as the water cools you'd create an equall amount of vacuum that would collapse your hoses and likely your rad.
In an extremely high heat system the ideal would be a closed loop no-loss (catch-can) system just like an automotive cooling system has.
Old March 29, 2009, 10:55 PM
MpG's Avatar
MpG MpG is offline
The only remotely legit application for the filter than I can think of might be to catch bits of seal that break off from the insides of some waterblocks. But that's a poor substitute for cracking the block open beforehand and inspecting it.
As for the pressure relief valve, if you need that, you've got bigger problems than a little excess pressure. The only legit time that I've noticed a little pressure build-up is in a completely sealed loop that been loaded/heated up for the first time, since you'll get a small amount of gas leaving solution from the warmer water, and not redissolving afterwards. But that's nowhere near problematic, and it's nothing unscrewing the res cap for a few seconds won't take care of.
Old March 30, 2009, 04:23 AM
3.0charlie's Avatar
Never fill a res to the top, leave some air space for pressure build-up - if any.
Hydro-Quebec is salivating...
Old March 30, 2009, 08:02 AM
gingerbee's Avatar
pressure build up is not the thing you should be worried about its whats causing the pressure ( one of my systems even after 6 months has little to no pressure just listen when you open the res watch what you put in your loop)
Google to buy Valve cwestwell Press Releases & Tech News 15 September 18, 2008 03:28 PM
Valve Hardware Survey Hardware Canucks Press Releases & Tech News 6 May 21, 2008 01:29 PM
Positive vs Negative Pressure? RCKage Air Cooling 2 March 16, 2008 03:27 PM
Am I getting Valve: Black Box with my HIS 3850 from DirectCanada? AFG34 Video Cards 5 December 14, 2007 09:50 AM
Getto Cooling relief for X Generation Cards Shredder Video Cards 6 April 16, 2007 08:38 PM
