Old June 15, 2007, 08:31 AM
Ok my galaxy dxx 850 is fine cause the 9 fines, 2 HDD's, and cold cathodes all power up. In fact the PSU will start up with just one fan.
I went with two loops cause I didn't want to overload one. I've got e6700 and an 8800 GTX on one and NB and 4 gigs of OCZ flex on the other. I may add more down the road such as second GPU.
I haven't given up yet, I'm still working on it.
Old June 15, 2007, 10:05 AM
3.0charlie's Avatar
Good - sorry about my rant. Your first reply gave me the idea that you gave up on the pumps.
Have you checked the pumps' potentiometers?
Old June 15, 2007, 10:08 AM
Yeah I applied power and turned the dial but there was still no action.
Old June 15, 2007, 11:18 AM
Misoprostol
Guest
Posts: n/a
I find it pretty hard to believe that you got TWO bad MCP655s at the same time. Overall it's a very reliable pump. There's got to be another explanation. Have you run them dry? If that's the case, then that's probably why they won't start. If not, have you tried forcing water through them while you start them?
Old June 15, 2007, 12:12 PM
Ok issue resolved. Swifttech just called me and it turns out whoever wired the pump put the wires on the wrong side of the molex connectors. Apparently I'm not the only one who's had this problem recently. The wires were setup on the red side of the molex when they're supposed to be on the yellow side. My pumps work fine and I can continue with my completion. YAHOO!!!
Old June 15, 2007, 12:21 PM
Misoprostol
Guest
Posts: n/a
.... interesting. that's a very odd issue.
Old June 15, 2007, 03:10 PM
Patriote's Avatar
LOL... Yeah thats odd. Anyway, glad you got them working!
• - Asus P8Z68-V PRO
• - Intel I5 2500k @ 4.5Ghz (for now)
• - Asus Geforce 580GTX DirectCUII Fermi
• - 16GB Corsair Vengeance Low Profile
• - Ultra X3 1000 Watt
• - Asus Xonar DX 7.1 \ Klipsch Promedia 2.1 THX
• - Corsair Vengeance 1300 Gaming Headset
• - Crucial M4 SSD 128GB \ WD Caviar Black 1TB
• - CoolerMaster 690II Advanced
• - Dell UltraSharp 24''
• - Noctua NH-D14
Old June 15, 2007, 04:55 PM
3.0charlie's Avatar
Bad wiring on BOTH pumps. Not bad. Show us some pics of that double loop.
John
  #19 (permalink)
Old June 15, 2007, 07:18 PM
Babrbarossa's Avatar
Congrats!- glad to have this onfo presented here- could save some others alot of time and heartache.
psst, wanna see my binder?
  #20 (permalink)
Old June 16, 2007, 05:22 PM
I'll get some pics up soon. Keep in mind this is my first attempt at water so take it easy on me.
CoolerMaster CM Stacker 832
Enermax Galaxy Dxx 850W
Intel e6700 lapped/D-tek Fuzion
EVGA 680i A1/Swiftech MCW30 NB cooler
4Gb OCZ Flex XLC DDR2 PC2-6400
EVGA 8800 ACS3 KO GTX with EK waterblock
Auzentech X-Fi Prelude
2x500Gb Seagate Barracuda SATA2
Dual loop with Thermochill Pa120.2 and 120.3
SLI question gimark Video Cards 3 February 7, 2008 08:54 AM
ups question t0m Power Supplies 5 January 10, 2008 01:04 AM
RAM question Salavat23 RAM 18 December 24, 2007 07:31 AM
SLI Question mattydies Video Cards 2 October 3, 2007 06:59 AM
p35 question Jim CPU's and Motherboards 6 August 28, 2007 02:44 PM
