Old March 27, 2009, 10:21 AM
AERo's Avatar
Default Question about Danger Den radiator barb fittings
I just got these things: Danger Den 1/2IN Polyethylene Barb Fittings 3/8 NPT
NCIX.com - Buy Danger Den 1/2IN Polyethylene Barb Fittings 3/8 NPT (Pair) - FIT-K200 In Canada.
On the barb fittings' thread, there is some white stuff.
Is it some sealant or something to fill in the gap of the thread and radiator?
Thanks for the help.
AMD64 Phenom X4 940 @ 3.6GHz G.Skill Black π 2x2GB
Asus M3A78-EM
Powercolor 4870x2
OCZ Vertex 120GB, Kingston V 128GB, Raptor X,
Antec Mini P180 CM UCP 700W
Samsung 240T, 226BW
Logitech G15, Microsoft X8
Watercooled by:
Swiftech Storm Rev.2 , 4870x2 FCB
1xMCP350 w/Petrastops , MCR220 QP , MCRES-MICRO , Tygon 1/2" ID
2 x Scythe Kama Ultra 1000
Old March 27, 2009, 11:24 AM
ChuckleBrother's Avatar
Not sure but I would recommend trading up for some metal fittings. Plastic ones are easier to collapse if you overtighten your clamps and to be quite frank, plastic on plastic is a right b***h to work with. The tubing will STICK to these fittings in a bad way, I have an old T that I can never use because I quite honestly can't remove the tubing without damaging the barbs.
"...you play a mean banjo"
Old March 27, 2009, 11:30 AM
Lpfan4ever's Avatar
Straight from the NCIX page:
Pre-wrapped with teflon tape for a leak proof seal.
Originally Posted by encorp
Code:
<firebane> slightly used
Old March 27, 2009, 08:15 PM
AERo's Avatar
leak proof my arse...
I running my watercooling setup to see for any leaks, and the only thing leaking is the
damn dangerden barbs I bought...
any suggestions to seal this up?
Asus M3A78-EM
Powercolor 4870x2
Samsung 240T, 226BW
Watercooled by:
Old March 27, 2009, 08:44 PM
Dazmode's Avatar
Get metal barbs. Plastic is junk. Plus teflon wrapping can dissolve get in your loop, especially if you use some additives.
Old March 27, 2009, 08:56 PM
AERo's Avatar
where can I get metal barbs?
I need a 3/8 NPT to 1/2IN barb fitting
Asus M3A78-EM
Powercolor 4870x2
Samsung 240T, 226BW
Watercooled by:
Old March 27, 2009, 09:04 PM
Dazmode's Avatar
NCIX should have some.
Browse their water cooling section.
Old March 27, 2009, 09:19 PM
G 3/8 threading and 1/2" IN
NCIX.com - Buy Bitspower 1/2IN High Flow Nickel Plated Thermochill G3/8 Barb Fittings (2 Pack) - BP-WTP-C15 In Canada.
Enjoy responsibly.
Old March 27, 2009, 10:18 PM
AERo's Avatar
isn't g 3/8 is different from 3/8 npt?
I've checked NCIX, they don't have anything that is "specifically"
3/8 NPT except the useless dangerden ones
I just bought...
Anyone know of some kind of material I could just use around the barb fitting?
I don't care if the material bonds permanently with the barb, as long as it becomes
leak-free. Also, if should be a material that still works while there is some liquid around the target area.
BTW, does anyone have any solutions if problem is ****ed up threading?
Swiftech stuff isn't always quality assured back when I bought my radiator;
my swiftech radiator is pretty bad (chipped off paint, barb fitting hole/thread crooked...)
Asus M3A78-EM
Powercolor 4870x2
Samsung 240T, 226BW
Watercooled by:
Old March 28, 2009, 06:00 AM
Are these for a thermochill radiator? Because Swiftech's AFAIK use G1/4 not 3/8.
If it IS a thermochill then the fittings I linked should be good.
Fittings Issue JD Water Cooling 6 February 15, 2009 07:15 AM
[WTB] 8800GT 512mb + EK full cover block + 90 degree barb jporter91 Buy/Sell & Trade 0 December 13, 2008 05:30 PM
Pump: Danger Den DDCPX-PRO Question Poison Ivy Water Cooling 9 October 24, 2008 11:55 AM
Barb Question Supergrover Water Cooling 4 October 21, 2008 05:37 AM
Radiator Question Scart Water Cooling 22 March 12, 2008 01:49 AM
