Old March 27, 2009, 08:43 AM
Dazmode's Avatar
Default What do you guys think about new Feser radiator optimized fans?
Hi everybody,
Feser will be coming with new radiator optimized fans. Check this video:
YouTube - TFC TRIEBWERK PROTOTYPE TESTING - 120 PC RADIATOR/CHASSIS FAN
I personally like the looks and noise numbers (on paper) but they won't be not cheap... twice or 3 times more then regular fans.
Is this something you'd like to see in Canada?
Old March 27, 2009, 09:17 AM
element291's Avatar
Originally Posted by Dazmode View Post
Hi everybody,
That guys voice is annoying as hell.
| ASUS P8Z68-VPRO | Intel i5 2500K | 8Gb Patriot Viper Xtreme | 2x 60gb OCZ Solid 3 SSD | EVGA GTX260 Core216 |
Old March 27, 2009, 09:21 AM
Dazmode's Avatar
Feser's folks a bit weird seems they never sleep, but they are complete fanatics of their stuff. I think Feser is the most self-motivated company in water cooling business at the moment.
Old March 27, 2009, 09:40 AM
Cptn Vortex's Avatar
Great design. Small motor hub, and looks like they extended the back of the fan casing to make a bit of a shroud, rather than having to buy shrouds. I bet these will work quite well.
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.2GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
Old March 27, 2009, 09:55 AM
ChuckleBrother's Avatar
They look crazy fat though. Tack those on one of their rads or their "monsta" rads and you have something that will fit in only a handful of cases
Hopefully they will be decently priced and good performance. If my TJ09 had more space I would consider these puppies.
"...you play a mean banjo"
Old March 27, 2009, 09:56 AM
gingerbee's Avatar
nice deep fans it's about time somebody did this i started to put 2 1200mm fans together (you don't think so try it) check out the turbine mods from Case mods and PC Modding Supplies turbine mod
Old March 27, 2009, 11:01 AM
Dazmode's Avatar
Yes, this is good way to put it. It is double thick and aerodynamically shaped inside, like jet turbine. Patented design.
Old March 27, 2009, 12:58 PM
JD JD is offline
These fans were specifically made for the Monsta BTW. And they are made by NoiseBlocker so they shouldn't be too noisy.
Old March 27, 2009, 01:13 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Depends on which Noiseblocker line. Some of them are less than optimal in the noise dept. ;)
Old March 27, 2009, 01:14 PM
MpG's Avatar
MpG MpG is offline
I'm a little skeptical that those fans will amount to much special, beyond the novelty and looks. The vast majority of static pressure comes from raw rpms, with fan thickness being a secondary factor. I'm sure they'll do decently enough, but I'd be surprised if these could outperform a pair of 25's in push-pull. And kind of a small motor hub, I must say. Silenx fans have a similar approach, and they've been known to burn right out during normal use.
Do any CDN distributors have Feser rads in stock? Liu Kang Water Cooling 6 March 27, 2009 08:29 AM
Feser Xchanger Triple... where to buy? vinister Water Cooling 29 March 9, 2009 10:54 PM
[WTB] Thermochill PA.120.2/3 Or Feser 240 radiator... Apollo4g Buy/Sell & Trade 0 February 18, 2009 11:06 PM
WTB Feser One Blue UV PLEASE!! @_@ EDMCR Buy/Sell & Trade 2 July 30, 2008 05:25 PM
