Old March 27, 2009, 11:41 AM
"Quote This..."
Can't you see the leak anywhere? Should at least leave a stain.
Old March 27, 2009, 12:02 PM
MpG's Avatar
MpG MpG is offline
You can also try the approach of geting a 1/2" tubing barb that screws onto a sink faucet. Plug up the outlet on the rad, hook up the inlet to the sink, and add a little pressure (just a little to start!), and look for leaks. Household pressure is around 50psi, iirc, so you definitely have enough to pressurize with. As a side bonus, this setup is great for flushing new radiators.
Old March 27, 2009, 12:21 PM
Soultribunal's Avatar
Fair enough Biff. On a side note, if you have the screw on type fittings for that Rad, I"d double check the O-Rings as well, because that is another possible spot for a Leak.
Just a thought.
Good luck, its gotta be a pain to chase a Coolant Leak.
ST
www.realhardwarereviews.com
Old March 27, 2009, 05:55 PM
3.0charlie's Avatar
I have been searching a slow leak on my rig for 2 weeks now - still no luck. In the Xspc res, there is a loss of liquid equal to about 1/16" high. Not much, may be due to evaporation, but still.... it bugs me.
Hydro-Quebec is salivating...
Old March 27, 2009, 05:59 PM
MpG's Avatar
MpG MpG is offline
It's not just microbubbles? Considering how poorly they bleed, you can easily have microbubbles trickling out of the reservoir's main line of flow for weeks after the loop is 'bled'.
Old March 27, 2009, 06:10 PM
3.0charlie's Avatar
Weeks? Damn... though I see no bubbles passing by the end of the inlet tube and outlet pump hole.
Old March 27, 2009, 06:24 PM
MpG's Avatar
MpG MpG is offline
Microbubbles. Extremely tiny ones. I have to hold my eyeball right up the glass and stare for a little to see them occasionally leave the main coolant flow. But over the course of two weeks, I could imagine them possibly equaling 1/8" fluid drop total. I'm only guessing, mind, but that's been my own experience with this reservoir.
Old March 27, 2009, 06:29 PM
3.0charlie's Avatar
Shit. You are correct. Took me a few minutes of staring, but I did see a few pass by, and reach the top of the res. Thank you.
